| loading a Class object from an extension point [message #298274] |
Fri, 27 January 2006 10:57  |
We have an extension for which we'd like to allow an extension point to
give us the name of a class in their plugin, and we'd get the instance
of java.lang.Class corresponding to that class while we are processing
their extension point. There doesn't seem to be a way to do this, directly.
Here's what we're doing today as a workaround.
In our extension, we require that the name of a factory class be passed
in as one of the extension point element attributes. We then use
IConfigurationElement.createExecutableExtension() to have the factory
created. That factory is required to implement a method which basically
just does a Class.forName(). Quite yucky, because it requires our users
to create this stupid class which just does a Class.forName(); and
requires an additional attribute in the extension point.
I guess what I'd like to see is a peer of createExecutableExtension()
called, say, loadClass() that would just load the class and return the
instance of java.lang.Class. Which is clearly part of what
createExecutableExtension() is already doing today.
I would be willing to add some bundle-y goop to my plugin that defines
the extension, to get this to work, but I don't want to force my
downstream uses (folks that use our extension via extension points) to
HAVE to use bundle-y goop.
Any other alternatives, since our workaround is rather ... untasty? Or
shall I make a new feature request via Bugzilla, or is the issue moot
because of other reasons (WE'LL NEVER EVER DO THIS BECAUSE OF x, y, z!)
Patrick Mueller - pmuellr@yahoo.com
Oblique Strategies: A very small object - It's centre
| Re: loading a Class object from an extension point [message #298275 is a reply to message #298274] |
Fri, 27 January 2006 11:11  |
--------------060906030906020405000406
Patrick,
This approach is what's happening under the covers:
Platform.getBundle("<plugin-ID>").loadClass("<name-of-class-visible-in-that-plugin >");
In EMF we often create "descriptors" to avoid plugin loading as long as
possible:
public static class PluginClassDescriptor
protected IConfigurationElement element;
protected String attributeName;
public PluginClassDescriptor(IConfigurationElement element,
String attributeName)
this.element = element;
this.attributeName = attributeName;
public Object createInstance()
try
return element.createExecutableExtension(attributeName);
catch (CoreException e)
throw new WrappedException(e);
> to give us the name of a class in their plugin, and we'd get the
> instance of java.lang.Class corresponding to that class while we are
> processing their extension point. There doesn't seem to be a way to
> do this, directly.
> passed in as one of the extension point element attributes. We then
> use IConfigurationElement.createExecutableExtension() to have the
> factory created. That factory is required to implement a method which
> basically just does a Class.forName(). Quite yucky, because it
> requires our users to create this stupid class which just does a
> Class.forName(); and requires an additional attribute in the extension
> point.
> Or shall I make a new feature request via Bugzilla, or is the issue
> moot because of other reasons (WE'LL NEVER EVER DO THIS BECAUSE OF x,
> y, z!)
<html>
<head>
</head>
Patrick,<br>
<br>
This approach is what's happening under the covers:<br>
<blockquote><small>Platform.getBundle("<plugin-ID> ").loadClass("<name-of-class-visible-in-that-plugin> ");</small><br>
</blockquote>
possible:<br>
<blockquote><small> public static class PluginClassDescriptor <br>
{<br>
protected IConfigurationElement element;<br>
protected String attributeName;<br>
<br>
public PluginClassDescriptor(IConfigurationElement element, String
attributeName)<br>
{<br>
this.element = element;<br>
this.attributeName = attributeName;<br>
}<br>
<br>
public Object createInstance()<br>
{<br>
try<br>
{<br>
return element.createExecutableExtension(attributeName);<br>
}<br>
catch (CoreException e)<br>
{<br>
throw new WrappedException(e);<br>
}<br>
}<br>
}</small><br>
</blockquote>
<br>
<blockquote cite="middrdfst$9bi$1@utils.eclipse.org" type="cite">We
directly.
<br>
<br>
<br>
<br>
point.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------060906030906020405000406--
FUDForum. Page generated in 0.03536 seconds
