Cannot complete a provisioning operation successfully [message #1593197] |
Fri, 30 January 2015 13:27 |
Dave Hartnoll Messages: 6 Registered: January 2015 |
Junior Member |
I'm interesting in using Oomph to install a suitable development environment for an RCP-based product. As part of the learning process I'm trying to see how it works for some Eclipse projects but I can't get any kind of installation to complete successfully.
I'm using version 1.0.0 Build 876 on Windows 7 64-bit.
I've tried a few different versions of Eclipse (RCP/RAP, Standard, Committers) and different projects (Oomph, Vex) with and without target platforms being selected (Luna, Mars, None), but I always get the same error at the "Performing Targlets (...)" stage. This stack trace is from the Committers + Oomph + Mars combination:
Performing Targlets (Eclipse Platform + Oomph)
Cannot complete the request. Generating details.
ERROR: org.eclipse.equinox.p2.director code=10053 Cannot complete the install because one or more required items could not be found.
at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:656)
at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl$4.run(TargletTaskImpl.java:980)
at org.eclipse.oomph.util.pde.TargetPlatformUtil.runWithTargetPlatformService(TargetPlatformUtil.java:125)
at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl.perform(TargletTaskImpl.java:905)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2755)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2715)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:3768)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:3762)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:3760)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2706)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2681)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2620)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:523)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:608)
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1422623236823
ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: artificial_root 1.0.0.v1422623236823 requires 'org.eclipse.oomph.all.feature.group 0.0.0' but it could not be found
Am I doing something wrong?
[Updated on: Fri, 30 January 2015 13:32] Report message to a moderator
Re: Cannot complete a provisioning operation successfully [message #1593389 is a reply to message #1593197] |
Fri, 30 January 2015 16:03 |
Hi Dave,
I just tried it here and it works perfectly for me. Can you find the Git clone on your disk? Is it intact?
Cheers
/Eike
http://www.esc-net.de
Am 30.01.2015 um 14:28 schrieb Dave Hartnoll:
> I'm using version 1.0.0 Build 876.
> not be found.
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Cheers
/Eike
Re: Cannot complete a provisioning operation successfully [message #1599439 is a reply to message #1593414] |
Tue, 03 February 2015 16:36 |
Junior Member |
I'm banging my head against the wall with this problem.
I can successfully install the Committers + Oomph + Mars combination as detailed in the original post on the following platforms:
OS X 64-bit, Oomph 1.0.0 Build 881
Linux 32-bit (VM), Oomph 1.1.0 Build 884
Windows XP 32-bit (VM), Oomph 1.1.0 Build 884
However, it will not complete successfully on my actual work PC where I want it:
Windows 7 64-bit, Oomph 1.1.0 Build 884
The error is always as detailed in the original post (except that the qualifier for artificial_root changes).
One significant difference is that the Win 7 PC is multi-core so I wondered whether a race condition might exist somewhere. I did try limiting the running Eclipse to a single core but that didn't change anything.
I'd appreciate any pointers towards what I should look at or try next.
On a separate note, I experienced a couple of other issues as well:
1. On the Mac, I tried to use ~ as the Root install folder (and eclipse_oomph as the Installation folder name). This caused all sorts of problems, the most bizarre being that the new eclipse_oomph folder was created inside the running Oomph.app package. The git clone also did not work. I tried again with the Root install folder set to /Users/Dave and everything worked fine.
2. I noticed what when a task fails, you get the option to go back to make changes. However, when you go back, the failed task is no longer in the list. You can simply click Finish and setup continues with the next task. That doesn't seem right to me.
Shall I create Bugzillas for any or all of these issues?
Re: Cannot complete a provisioning operation successfully [message #1599474 is a reply to message #1599439] |
Tue, 03 February 2015 17:05 |
Am 03.02.2015 um 17:36 schrieb Dave Hartnoll:
> platforms:
Maybe it's not a matter of the OS or architecture but something on (or not on) that particular box?
The artificial_root is an IU that's generated on the fly when the p2 profile is created or updated.
I doubt that the number of cores is relevant here.
I just can't imagine of a possible cause for this problem that happens only on one specific machine ;-(
Strange. I'll have to try it on a Mac...
> seem right to me.
That might indicate that the task hasn't properly cleanup up some partial disk state. Without knowing what task exactly
failed and how it's hard for me to judge.
Yes, please.
Cheers
/Eike
Cheers
/Eike
FUDForum. Page generated in 0.03338 seconds
