Deploying in Citrix causes fileTableLock (Access is denied) exception [message #297944] |
Mon, 23 January 2006 08:41  |
When I try to deploy my app in a Citrix env, I get an exception:
!Message Error reading configuration:
........\configuration\org.eclipse.osgi\manager\.fileTableLo ck (Access is
denied)
!Stack 0
java.io.FileNotFoundException:
denied)
at java.io.FileOutputStream.openAppend(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
If I add the osgi.locking=none setting to the configuration, the error goes
away but then, most documentation that suggests this setting, also warns
about a potential data corruption. I have also added the
osgi.instance.area=@user.home/temp to redirect the log information. This
temp location has read/write privileges but the directory where my
application is installed has been locked down.
What is the correct procedure to deploy in a locked down env? How can I
change the org.eclipse.core.runtime location to be different? The config.ini
currently has: org.eclipse.core.runtime@2:start as one of the bundles.
Re: Deploying in Citrix causes fileTableLock (Access is denied) exception [message #297971 is a reply to message #297944] |
Mon, 23 January 2006 12:00  |
Needed the osgi.configuration.area setting as well.
The RCP book by Jeff McAffer etal, just paid itself off.
"kumuksu" <kumuksu@hotmail.com> wrote in message
news:dr2mea$3n4$1@utils.eclipse.org...
> .......\configuration\org.eclipse.osgi\manager\.fileTableLoc k (Access is
> denied)
> !Stack 0
> denied)
> goes away but then, most documentation that suggests this setting, also
> warns about a potential data corruption. I have also added the
> config.ini currently has: org.eclipse.core.runtime@2:start as one of the
> bundles.
> Thanks
FUDForum. Page generated in 0.03481 seconds
