Home » Eclipse Projects » Eclipse Platform » TableViewer - sorting
TableViewer - sorting [message #297342] Thu, 12 January 2006 03:11 Go to next message
Originally posted by: popeye.netcabo.pt
When data is shown in the tableviewer, the data by default is sorted on any column or it simple puts the data in the table as it got the data from the input object? which is the sorter mechanism by default?
The point is that i want to add some row entries, 1 by one, in the table after it has been created and shown and i want that the new messages appear in the top of the table instead of being sorted by anything.
Marco
Re: TableViewer - sorting [message #297376 is a reply to message #297342] Thu, 12 January 2006 10:35 Go to previous messageGo to next message
See TableViewer.insert(Object, int).
Boris.
"Marco Ferreira" <popeye@netcabo.pt> schrieb im Newsbeitrag
news:23363933.1137053528501.JavaMail.root@cp1.javalobby.org...
> Marco
Re: TableViewer - sorting [message #297404 is a reply to message #297376] Thu, 12 January 2006 19:48 Go to previous messageGo to next message
This method is for update the viewer. it doesn't affect the model and is to be used inside a content provider when the new data is already present in the object input data. i want to affect the model, i.e., add a new entry in the input object after the viewer has been shown. i'm doing it. but when the object input data is displayed in the viewer the new message appear somehow sorted. i thought that it was straightforward, due to the last message(the new) has been placed in the top(or end) of my data structure (an ArrayList). I suspect that the viewer has a sorter by default. What is the default sorter mechanism? how can i disable it? or change it?
Marco
Re: TableViewer - sorting [message #297409 is a reply to message #297376] Fri, 13 January 2006 02:12 Go to previous message
thank you for the help, its working...
i put the viewer.insert(obj, 0) instead of the normal viewer.add(obj) in the inputChanged method of my content provider class.
at first, i didn't understood what you meant with that method. then after some hours i saw the solution...a bit dumb, but i'm a beginner.
Previous Topic:Want to change the order of properties from view
Next Topic:Synchronize with repository explorer is gone?
Current Time: Thu Oct 30 16:02:27 EDT 2025
Powered by FUDForum. Page generated in 0.07226 seconds
