Home » Archived » BIRT » Exporting Reports from Windows to Linux Environment
Exporting Reports from Windows to Linux Environment [message #1589122] Wed, 28 January 2015 03:47 Go to next message
I've got 3 different BIRT Reports, created with the Birt-Report-Designer 4.4.1.
Everything works fine on my Machine with Windows 7 installed an running on an Apache Tomcat 8.0.15 and jdk 1.7.0.67.
Database is Oracle 11g.
Now I need to change the Environment and export these 3 Reports to a Linux-Server.
Linux with Apache Tomcat 8.0.15 and jdk 1.7.0.67:
  • Report 1 - doesn't work, throws: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
  • Report 2 - works fine
  • Report 3 - exactly the same error as Report 1
Linux with Weblogic and jdk 1.7.0.67:
  • Report 1 - works fine
  • Report 2 - doesn't work, throws:
    org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details: Failed to prepare the query execution for the data set: test Cannot get the result set metadata. org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object. SQL error #1:ORA-12704: character set mismatch ; java.sql.SQLException: ORA-12704: character set mismatch
  • Report 3 - doesn't work, throws:
    Multiple exceptions occurred.
    (basically ORA-12704: character set mismatch aswell)
Can someone help me with this? Maybe some Ideas on what to look at in my Reports / App Servers / Database?
I was able to trace the ORA-12704: character set mismatch in Weblogic to one Dataset (used in Report 2 and 3), which means: as soon as I added that Dataset to e.g. a table-binding I got that error.
That dataset has the following SQL query:
WITH papp AS
	SELECT ? AS appsession from dual
,pstart AS
	SELECT ? AS startdate from dual
,pgroup AS
	SELECT ? AS groupin from dual
,pend AS
	SELECT ? AS enddate from dual
,ptype AS
	SELECT ? AS stype from dual
,pdt AS
	SELECT ? AS datatype from dual
,pdt1 AS
	SELECT ? AS datatype1 from dual
,pdt2 AS
	SELECT ? AS datatype2 from dual
,pdt3 AS
	SELECT ? AS datatype3 from dual
,pdt4 AS
	SELECT ? AS datatype4 from dual
,pdt5 AS
	SELECT ? AS datatype5 from dual
,pdt6 AS
	SELECT ? AS datatype6 from dual
select
    trunc(v.TIME_STAMP, pgroup.groupin) "Datum"
	,case UPPER(m.display_type)
	  when 'AVG' then (
		case md.metric_id
			when 1 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt1.datatype1,4))
			when 2 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt2.datatype2,4))
			when 3 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt3.datatype3,4))
			when 4 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt4.datatype4,4))
			when 5 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt5.datatype5,4))
			when 6 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt6.datatype6,4))
	  end
	  when 'MAX' then (
		case md.metric_id
			when 1 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt1.datatype1,4))
			when 2 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt2.datatype2,4))
			when 3 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt3.datatype3,4))
			when 4 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt4.datatype4,4))
			when 5 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt5.datatype5,4))
			when 6 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt6.datatype6,4))
	  end
	  when 'MIN' then (
		case md.metric_id
			when 1 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt1.datatype1,4))
			when 2 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt2.datatype2,4))
			when 3 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt3.datatype3,4))
			when 4 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt4.datatype4,4))
			when 5 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt5.datatype5,4))
			when 6 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt6.datatype6,4))
	  end
	  else dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2), 0)
	end metric_curr_value
	  when 'AVG' then round(avg(v.metric_value),2)
	  when 'MAX' then round(max(v.metric_value),2)
	  when 'MIN' then round(min(v.metric_value),2)
	  else avg(v.metric_value)
	end metric_value
	, md.metric_id
	,case ptype.stype
		when 'C' then
			case md.metric_id
			  when 1 then dbareport.dbareport_pkg.zDatatype(nvl(pdt1.datatype1,4))
			  when 2 then dbareport.dbareport_pkg.zDatatype(nvl(pdt2.datatype2,4))
			  when 3 then dbareport.dbareport_pkg.zDatatype(nvl(pdt3.datatype3,4))
			  when 4 then dbareport.dbareport_pkg.zDatatype(nvl(pdt4.datatype4,4))
			  when 5 then dbareport.dbareport_pkg.zDatatype(nvl(pdt5.datatype5,4))
			  when 6 then dbareport.dbareport_pkg.zDatatype(nvl(pdt6.datatype6,4))
			end
		else dbareport.dbareport_pkg.zDatatype(pdt.datatype)
	end datatype
    , c.customer_name || ' - ' || tt.target_type_desc || ' - ' ||
		t.target_name || ' - ' || m.metric_desc || ' - ' || md.metric_detail_desc description
from 	papp, pstart, pgroup, pend, ptype, pdt, pdt1,pdt2,pdt3,pdt4,pdt5,pdt6
	, dbareport.dbac_values v
    inner join dbareport.dbac_selection s
      on s.customer_id = v.customer_id
        and	s.target_id = v.target_id
        and s.metric_detail_id = v.metric_detail_id
    inner join dbareport.dbac_metric_detail md
      on md.metric_detail_id = s.metric_detail_id
    inner join dbareport.dbac_metric m
      on m.metric_id = md.metric_id
    inner join dbareport.dbac_target t
      on t.target_id = s.target_id
    inner join dbareport.dbac_target_type tt
      on t.target_type_id = tt.target_type_id
    inner join dbareport.dbac_customer c
      on s.customer_id = c.customer_id
where
    s.SESSION_ID = papp.appsession and
    v.time_stamp between to_date(pstart.startdate, 'dd.mm.yyyy hh24:mi')
      and to_date(pend.enddate, 'dd.mm.yyyy hh24:mi')
group by
	, m.display_type
	, md.metric_id
	, ptype.stype
	, pdt.datatype
	, pdt1.datatype1
	, pdt2.datatype2
	, pdt3.datatype3
	, pdt4.datatype4
	, pdt5.datatype5
	, pdt6.datatype6
order by
    , trunc(v.TIME_STAMP, pgroup.groupin)
Complete errors:
Apache Tomcat 8.0.15, Report 1 and 3:
   at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1114)
   at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1561)
   at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:204)
   at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:237)
   at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:104)
   at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
   at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
   at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Method.java:606)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
   at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
   at sun.reflect.GeneratedMethodAccessor64.invoke(Unknown Source)
   at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
   at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
   at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
   at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
   at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
   at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
   at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
   at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
   at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:644)
   at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
   at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
   at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
   at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
   at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
   at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
   at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
   at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:537)
   at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1085)
   at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:658)
   at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:222)
   at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1556)
   at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1513)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
   at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
   at java.lang.Thread.run(Thread.java:745)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
   at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2380)
   at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:325)
   at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1555)
... 54 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.birt.chart.device.svg.SVGRendererImpl
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Class.java:190)
   at org.eclipse.birt.core.framework.jar.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:46)
   at org.eclipse.birt.core.framework.eclipse.EclipseConfigurationElement.createExecutableExtension(EclipseConfigurationElement.java:35)
   at org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObject(PluginSettings.java:1252)
   at org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginSettings.java:632)
   at org.eclipse.birt.chart.api.ChartEngine.getRenderer(ChartEngine.java:119)
   at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.prepareDeviceRenderer(ChartReportItemPresentationBase.java:1222)
   at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.generateRenderObject(ChartReportItemPresentationBase.java:971)
   at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.onRowSets(ChartReportItemPresentationBase.java:904)
   at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationProxy.onRowSets(ChartReportItemPresentationProxy.java:108)
   at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:1074)
   at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeForeign(LocalizedContentVisitor.java:591)
   at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localize(LocalizedContentVisitor.java:176)
   at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:37)
   at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
   at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
   at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
   at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
   at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)
   at org.eclipse.birt.report.engine.layout.html.HTMLListLM.layoutChildren(HTMLListLM.java:72)
   at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
   at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
   at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:717)
   at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:321)
Weblogic - Report 2:
   at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1245)
   at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1224)
   at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
   at org.eclipse.birt.report.engine.executor.ListItemExecutor.execute(ListItemExecutor.java:66)
   at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
   at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
   at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
   at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
   at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
   at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:269)
   at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:86)
   at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
   at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
   at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
   at org.eclipse.birt.report.service.actionhandler.BirtGetPageActionHandler.__checkDocumentExists(BirtGetPageActionHandler.java:58)
   at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.prepareParameters(AbstractGetPageActionHandler.java:118)
   at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:103)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at sun.reflect.GeneratedMethodAccessor155.invoke(Unknown Source)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:751)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:844)
   at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280)
   at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254)
   at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136)
   at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:341)
   at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:25)
   at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79)
   at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3367)
   at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3333)
   at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
   at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
   at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
   at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2220)
   at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2146)
   at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2124)
   at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1564)
   at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:254)
   at weblogic.work.ExecuteThread.execute(ExecuteThread.java:295)
   at weblogic.work.ExecuteThread.run(ExecuteThread.java:254)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
   at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:657)
   at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:152)
   at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)
   at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:275)
   at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1947)
   at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 65 more
Caused by: org.eclipse.birt.data.engine.core.DataException: Failed to prepare the query execution for the data set: test
   at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:350)
   at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:463)
   at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
   at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
   at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:178)
   at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:637)
... 70 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the result set metadata.
   at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
   at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
   at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
   at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
   at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
   at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.declareCustomColumn(PreparedStatement.java:1223)
   at org.eclipse.birt.data.engine.executor.DataSourceQuery.addCustomFields(DataSourceQuery.java:684)
   at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepareColumns(DataSourceQuery.java:407)
   at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:345)
   at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:517)
   at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:346)
... 75 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
   at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:481)
   at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingPolicy1(Statement.java:420)
   at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:316)
   at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
   at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:423)
   at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:390)
   at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
... 82 more
Caused by: java.sql.SQLException: ORA-12704: character set mismatch
   at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
   at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
   at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:879)
   at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
   at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
   at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
   at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:207)
   at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:884)
   at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1167)
   at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1289)
   at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3594)
   at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3638)
   at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1495)
   at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:477)
... 88 more
Re: Exporting Reports from Windows to Linux Environment [message #1589655 is a reply to message #1589122] Wed, 28 January 2015 10:21 Go to previous messageGo to next message
In Tomcat, it seems to be having problems with the SVG renderer. Could you try changing the charts in those reports (I'm assuming those reports have charts) from SVG to PNG to see if that solves the issue?
Re: Exporting Reports from Windows to Linux Environment [message #1591049 is a reply to message #1589655] Thu, 29 January 2015 04:38 Go to previous messageGo to next message
Hi Michael,
Thanks for your response.
You were right that there are Charts in those 2 Reports.
I tried your suggestion (First with PNG, then with JPG) and the Error-Msg changed.
Now it's
Caused by: java.lang.NoClassDefFoundError: org.eclipse.birt.chart.device.swing.SwingRendererImpl
instead of the previous SVGRenderer.
Basically means the Chart-rendering is my Problem here (atleast with the Tomcat Server), right?
Any Idea what I could do from here on?
Full "new" Error-MSG:
... 54 more
... 55 more
Re: Exporting Reports from Windows to Linux Environment [message #1591686 is a reply to message #1591049] Thu, 29 January 2015 12:37 Go to previous messageGo to next message
Are you using the Oracle jdk or Open jdk? And you've got the jdk, not just the jre, correct?
Re: Exporting Reports from Windows to Linux Environment [message #1592944 is a reply to message #1591686] Fri, 30 January 2015 05:17 Go to previous messageGo to next message
I am using the Oracle JDK,
jdk1.7.0_67 in both the windows and the linux environment.
Saw that "solution" in another forum post aswell and therefore double-checked it.
Re: Exporting Reports from Windows to Linux Environment [message #1601338 is a reply to message #1592944] Wed, 04 February 2015 17:15 Go to previous messageGo to next message
You might try using the OSGi runtime instead of the POJO runtime to see if that works.
Re: Exporting Reports from Windows to Linux Environment [message #1634853 is a reply to message #1601338] Wed, 25 February 2015 08:42 Go to previous messageGo to next message
Can you please share how to deploy the '.rptdesing' file in linux.
Report working WINDOWS but not in the LINUX.
Whenever I run the report in tomcat from linux it throws a Exception.
Cannot open the connection for the driver:
org.eclipse.birt.report.data.oda.jdbc.dbprofile.
org.eclipse.datatools.connectivity.oda.OdaException: Unable to find the connection profile referenced by the data source connection properties. ;
org.eclipse.datatools.connectivity.oda.OdaException: Unable to find or access the named profile (birtconnectionprofile) in profile store path (/home/pro/Liferay/BIRTReport/BirtReport/lib/birtconnectionprofile). ;
org.eclipse.datatools.connectivity.oda.OdaException ;
java.lang.IllegalStateException: Unable to determine the default workspace location. Check your OSGi-less platform configuration of the plugin or datatools workspace path. (Element ID:95)
Hide Exception Stack Trace
Stack Trace:
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.dbprofile.
       at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1237)
       at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1216)
       at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96).
Re: Exporting Reports from Windows to Linux Environment [message #1654966 is a reply to message #1634853] Fri, 06 March 2015 18:00 Go to previous messageGo to next message
Sorry for the delay. You'd set the default workspace in the web.xml. It should be the root directory of the viewer by default.
Re: Exporting Reports from Windows to Linux Environment [message #1689398 is a reply to message #1654966] Mon, 23 March 2015 09:47 Go to previous messageGo to next message
Can you please share how to set the default workspace in the web.xml.
I am completely new to birt report.
Re: Exporting Reports from Windows to Linux Environment [message #1690063 is a reply to message #1689398] Tue, 24 March 2015 18:10 Go to previous message
Navigate to WEB-INF/web.xml, find the BIRT_VIEWER_WORKING_FOLDER parameter and set a value. You'll see above the parameter that the default value is BIRT home.
Previous Topic:Report Deployment
Next Topic:Cannot get any Library file to work
Current Time: Tue Sep 09 23:40:15 EDT 2025
Powered by FUDForum. Page generated in 0.08338 seconds
