Home » Modeling » EMF » [EMF] Wrong URI for proxy of controlled resource
| [EMF] Wrong URI for proxy of controlled resource [message #1587866] |
Tue, 27 January 2015 11:04  |
I'm currently working on Sirius bugzilla 458151 [1].
During the analysis, I think I discovered a bug in EMF.
Use case:
* A resource B.ecore with a package RootB.
* RootB contains a package b1 that is controlled in another B1.ecore
resource.
* b1 contains a package b2. And b2 contains a class ClassB.
Steps to reproduce:
* Unload B1 and call EcoreUtil.getURI(eClassB);
* The URI is something like "file:/myPath/B1.ecore#//b2.1/ClassB".
* I think it should have the same value as before the unload
"file:/myPath/B1.ecore#//b2/ClassB".
I create a simple Junit to reveal the problem [2].
My analysis:
During the unload, the ProxyURI is set on all EObject of B1.ecore.
For computation of URI fragment of ClassB, I think that there is a
problem in EModelElementImpl.eURIFragmentSegment(EStructuralFeature,
EObject), corresponding stack is here [3].
The eObject parameter is the parent proxy b2 (with a eProxyURI =
"file:/myPath/B1.ecore#//b2").
The method eContents() returns another instance, not a proxy,
corresponding to this package, because the eContents() resolves the
proxy. The resolution is done because we are in a
ResolvingFeatureIteratorImpl. So just after the test "if (otherEObject
== eObject)" return false because eObject is a proxy of b2 and
otherEObject is b2.
Perforce, name.equals(otherENamedElement.getName() and the ". + count"
is added to the name.
Is it a bug or not?
Perhaps a test like
if (container.eIsProxy())
should be added in method
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getURIFragment(EObject)
and in this case consider
container.eProxyURI().fragment()
Thank you for your help!
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=458151
[2] https://bugs.eclipse.org/bugs/attachment.cgi?id=250268
[3] Corresponding stack
EPackageImpl(EModelElementImpl).eURIFragmentSegment(EStructuralFeature,
EObject) line: 334
EcoreResourceFactoryImpl$1(ResourceImpl).getURIFragment(EObject) line: 670
EcoreResourceFactoryImpl$1(XMLResourceImpl).getURIFragment(EObject)
line: 548
EcoreResourceFactoryImpl$1(ResourceImpl).unloaded(InternalEObject) line:
1574
EcoreResourceFactoryImpl$1(ResourceImpl).doUnload() line: 1635
EcoreResourceFactoryImpl$1(XMLResourceImpl).doUnload() line: 631
EcoreResourceFactoryImpl$1(ResourceImpl).unload() line: 1650
EMFUnloadWithStrangeProxyURITests.init(boolean) line: 113
EMFUnloadWithStrangeProxyURITests.testURIAfterUnloadWithFragment() line: 50
Laurent - Obeo
| Re: [EMF] Wrong URI for proxy of controlled resource [message #1591087 is a reply to message #1587866] |
Thu, 29 January 2015 05:02   |
here is a copy of exchanges with Ed (his first answer was in private by
mistake).
> I continue to investigate.
> By adapting the JUnit test, I observed that the behavior is different if B1.ecore is a fragment of B.ecore or if B1.ecore is a "standalone" resource.
> In case of B1.ecore as "standalone" resource, the behavior is OK. But if B1.ecore is a fragment, there is the mentioned bug.
> The difference is in BasicEObjectImpl.eInternalResource(). In case of "standalone" resource, no resource is returned. And so the proxy is not resolved. And so, the initial problematic test "if (otherEObject
> == eObject)" return true. But in case of fragment, the "parent" resource is returned, B.ecore, in our case. And this is sufficient to resolve the proxy and then have the problem.
> Is it expected to have such a different behavior?
> The corresponding calling stack in both case:
> EPackageImpl(BasicEObjectImpl).eInternalResource() line: 939
> EPackageImpl(BasicEObjectImpl).eResource() line: 920
> EcoreUtil.resolve(EObject, EObject) line: 258
> EPackageImpl(BasicEObjectImpl).eResolveProxy(InternalEObject) line: 1473
> EObjectContainmentWithInverseEList$Resolving<E>(EcoreEList<E>).resolveProxy(EObject) line: 206
> EObjectContainmentWithInverseEList$Resolving<E>(EcoreEList<E>).resolve(int, EObject) line: 161
> EObjectContainmentWithInverseEList$Resolving<E>.resolve(int, E) line: 105
> EObjectContainmentWithInverseEList$Resolving<E>(BasicEList<E>).get(int) line: 348
> ENamedElementImpl$1$1(EContentsEList$FeatureIteratorImpl<E>).hasNext() line: 471
> EPackageImpl(EModelElementImpl).eURIFragmentSegment(EStructuralFeature, EObject) line: 332
> EcoreResourceFactoryImpl$1(ResourceImpl).getURIFragment(EObject) line: 680
> EcoreResourceFactoryImpl$1(XMLResourceImpl).getURIFragment(EObject) line: 630
> EcoreResourceFactoryImpl$1(ResourceImpl).unloaded(InternalEObject) line: 1594
> EcoreResourceFactoryImpl$1(ResourceImpl).doUnload() line: 1655
> EcoreResourceFactoryImpl$1(XMLResourceImpl).doUnload() line: 713
> EcoreResourceFactoryImpl$1(ResourceImpl).unload() line: 1670
> EMFUnloadWithStrangeProxyURITests.init(boolean) line: 114
> EMFUnloadWithStrangeProxyURITests.testURIAfterUnloadWithFragment() line: 51
> Is it deliberate to answer only to me (and not to all on forum)?
> Le 27/01/2015 19:21, Laurent Redor a écrit :
>> Le 27/01/2015 18:51, Ed Merks a écrit :
>>> Laurent,
>>> Comments below.
>>> On 27.01.2015 17:04, Laurent Redor wrote:
>>>> Hello,
>>>> Use case:
>>>> resource.
>>> As I always point out, nested packages are syntactic rat poison that are more likely to cause problems than actually make anything nicer...
>> This is not our real use case. I try to reproduce with a simple example.
>>>> Steps to reproduce:
>>> Is eClassB.eIsProxy() true? If you cast to InternalEObject, is eProxyURI the URI you show? Which version of EMF are you using?
>> Yes. yes. I try with several versions of EMF (including juno 2.8.3.v20130125 and luna 2.10.1.v20140901).
>>>> My analysis:
>>>> otherEObject is b2.
>>>> Is it a bug or not?
>>> It sounds kind of familiar. I wonder if you're using the latest release?
>> I've not tested with the current mars release.
>>>> Perhaps a test like
>>>> Best regards,
>>>> EObject) line: 334
>>>> line: 548
>>>> 1574
Laurent - Obeo
Need professional services for Sirius?
| Re: [EMF] Wrong URI for proxy of controlled resource [message #1591095 is a reply to message #1591087] |
Thu, 29 January 2015 05:06   |
I will create a bugzilla for further analysis and try to propose a fix.
In fact, I think we can adapt the method
(EObject) to avoid calling eURIFragmentSegment for containers being
themselves proxy.
> mistake).
>> resource.
>> line: 1473
>> line: 206
>> EObject) line: 161
>> 348
>> line: 471
>> line: 332
>> 680
>> line: 630
>> line: 1594
>> line: 51
>>>> Laurent,
>>>> Comments below.
>>>>> Hello,
>>>>> Use case:
>>>>> resource.
>>>>> Steps to reproduce:
>>>>> My analysis:
>>>>> otherEObject is b2.
>>>>> Is it a bug or not?
>>>> release?
>>>>> Perhaps a test like
>>>>> Best regards,
>>>>> EObject) line: 334
>>>>> line: 670
>>>>> line: 548
>>>>> line:
>>>>> 1574
>>>>> line: 50
Laurent - Obeo
| Re: [EMF] Wrong URI for proxy of controlled resource [message #1591392 is a reply to message #1591095] |
Thu, 29 January 2015 08:56  |
Corresponding bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=458721
> themselves proxy.
>> mistake).
>>> Hi,
>>> resource.
>>> line: 1473
>>> line: 206
>>> EObject) line: 161
>>> 105
>>> line:
>>> 348
>>> line: 471
>>> EObject)
>>> line: 332
>>> 680
>>> line: 630
>>> line: 1594
>>> line: 51
>>>>> Laurent,
>>>>> Comments below.
>>>>>> Hello,
>>>>>> Use case:
>>>>>> resource.
>>>> example.
>>>>>> Steps to reproduce:
>>>>>> My analysis:
>>>>>> (otherEObject
>>>>>> otherEObject is b2.
>>>>>> count"
>>>>>> Is it a bug or not?
>>>>> release?
>>>>>> Perhaps a test like
>>>>>> Best regards,
>>>>>> EObject) line: 334
>>>>>> line: 670
>>>>>> line: 548
>>>>>> line:
>>>>>> 1574
>>>>>> line: 50
Laurent - Obeo
Current Time: Tue Oct 28 06:45:00 EDT 2025
Powered by FUDForum. Page generated in 0.07156 seconds
