Home » Eclipse Projects » Eclipse Platform » C# plugin for Eclipse?
C# plugin for Eclipse? [message #296336] Tue, 20 December 2005 16:42 Go to next message
Originally posted by: atomicseasoning.hotmail.com
Is there a reliable plugin for Eclipse so that C# program files can be
created, compiled, and debugged?
Also where would I install the plugin in Eclipse, if it is a jar file, for
example?
Re: C# plugin for Eclipse? [message #296343 is a reply to message #296336] Tue, 20 December 2005 18:59 Go to previous messageGo to next message
Originally posted by: h_alhakami.yahoo.com
You can download it from the following site:
http://www.improve-technologies.com/alpha/esharp/
The instruction are there.
Regareds
Re: C# plugin for Eclipse? [message #296344 is a reply to message #296343] Tue, 20 December 2005 21:17 Go to previous messageGo to next message
Thanks for the link. I followed the installation instructions on this
webpage,
http://www.improve-technologies.com/alpha/ressources/usingTh eUpdateManager.html
and Eclipse now recognises my .cs files as C#, however when I click on the
red square that now appears along the far right end of the icon tool bar
an error box pops up which says "Before building your source code, you
have to specify the location of the C# compiler."
Where do I go in Eclipse to specify the location of the C# compiler?
(I'm sure the software from the above website was downloaded to a folder
within the plugins folder in eclipse.)
Re: C# plugin for Eclipse? [message #296355 is a reply to message #296344] Wed, 21 December 2005 00:37 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
> webpage,
> on the red square that now appears along the far right end of the
> icon tool bar an error box pops up which says "Before building your
> source code, you have to specify the location of the C# compiler."
Did you try looking at Preferences?
Sunil
Re: C# plugin for Eclipse? [message #296364 is a reply to message #296355] Wed, 21 December 2005 06:51 Go to previous message
Thanks. I set the C# compiler path to
C:\Eclipse\eclipse\plugins\fr.improve.csharp.ui_2.0.1\CSharp UI.jar
or
C:\Eclipse\eclipse\plugins\fr.improve.csharp.ui_2.0.1\src\fr \improve\csharp\ui\internal\Compiler.properties
but nothing happens when I click on the red square. Are neither of these
the compiler file for C#? What would the file extention be for the
compiler?
(*If one of the files above is the right one, would I then run & debug it
like Java files?)
Previous Topic:Preferences vs plugin.xml classpath change problem
Next Topic:update editores
Current Time: Sun Oct 26 22:17:18 EDT 2025
Powered by FUDForum. Page generated in 0.05396 seconds
