Home » Eclipse Projects » Eclipse Platform » Eclipse won't start: An error occured while automatically activating bundle org.eclipse.core.resourc
Eclipse won't start: An error occured while automatically activating bundle org.eclipse.core.resourc [message #294911] Fri, 18 November 2005 15:52 Go to next message
I have a user which can't launch Eclipse. It gives an error dialog
indicating error and to check the .log file. Eclipse display the splash
screen, and about 3 seconds later, it gives the error dialog, and
Eclipse fails to start. It's failing early in the start up.
Below is the error I'm seeing.
By copying the workspace to a different linux system, I have determine
that at least it's something in the .metadata directory. If I erase the
..metadata, then Eclipse starts.
Anyone know how I can debug this further to find what metadat is
currupted? Oh... the is eclipse 3.0.2.
Thanks for any ideas.
frank
!SESSION Nov 18, 2005 12:38:48.880
eclipse.buildId=M200503110845
java.version=1.4.2_09
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi Nov 18, 2005 12:38:48.881
!MESSAGE An error occured while automatically activating bundle
org.eclipse.core.resources (46).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t() of
bundle org.eclipse.core.resources.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoader.java:336)
org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(BundleLoader.java:914)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.ui.internal.ide.model.WorkbenchAdapterFactory.<init >(WorkbenchAdapterFactory.java:26)
org.eclipse.ui.internal.ide.model.WorkbenchAdapterBuilder.re gisterAdapters(WorkbenchAdapterBuilder.java:33)
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.initialize(I DEWorkbenchAdvisor.java:155)
org.eclipse.ui.application.WorkbenchAdvisor.internalBasicIni tialize(WorkbenchAdvisor.java:165)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:789)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Caused by: org.eclipse.core.internal.resources.ResourceException: The
resource tree is locked for modifications.
org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:93)
org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1628)
at org.eclipse.core.internal.resources.Workspace.close(Workspac e.java:298)
org.eclipse.core.resources.ResourcesPlugin.shutdown(Resource sPlugin.java:324)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:52)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
... 30 more
Root exception:
org.eclipse.core.internal.resources.ResourceException: The resource tree
!ENTRY org.eclipse.osgi Nov 18, 2005 12:38:48.889
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IProject
Re: Eclipse won't start: An error occured while automatically activating bundle org.eclipse.core.res [message #295383 is a reply to message #294911] Tue, 29 November 2005 05:41 Go to previous messageGo to next message
Hi Frank,
Already found a solution? I'm experiencing the same problem...
Cheers
Nils
Frank Parrott schrieb:
> frank
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 30 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Eclipse won't start: An error occured while automatically activating bundle org.eclipse.core.r [message #295399 is a reply to message #295383] Tue, 29 November 2005 11:56 Go to previous message
Originally posted by: automatic.javalobby.org
It might be the permissions on the .metadata directory. If you've just copied your workspace over to his, and he tries to create entries in the metadata, then he may not be able to write entries into it. Either that, or the workspace might point to projects that he can't read (e.g. have references to /home/you/projet, and /home/you isn't world-readable).
As for which problem it is; it looks like it's coming from the org.eclipse.core.resources plugin, so you could trash the .metadata/.plugins/org.eclipse.core.resources preferences, but you're probably better off trashing the whole .metadata directory. If you need to get preference from on user's install to another, it's much better to export the preferences (Window -> Preferences -> Export) and then import them into the new one.
Alex.
Previous Topic:Image and text button
Next Topic:Sharing a top level menu between an Editor and perspective (& other objects)
Current Time: Mon Nov 10 07:15:49 EST 2025
Powered by FUDForum. Page generated in 0.03897 seconds
