Home » Archived » BIRT » Setting parameters via API
Setting parameters via API [message #294449] Thu, 24 January 2008 16:53 Go to next message
Originally posted by: pmills.systemcore.ca
I'm missing something that I suspect must be obvious. Using the report
engine API, I have no problem running and rendering a report. I also see
calls to find out all kinds of information about report parameters through
the IGetParameterDefinitionTask. What I don't see is the mechanism for
setting a parameter.
Let's say I schedule a report to run every Sunday night to calculate the
past week's activity. In my scheduler code (Java), I know the start and
end times, which I want to map to '?' parameters in my SQL. What chain of
events has to happen?
Re: Setting parameters via API [message #294455 is a reply to message #294449] Thu, 24 January 2008 18:13 Go to previous messageGo to next message
Phillip,
In the report engine api the run task and the runandrendertask have
methods that use task.setParameterValue(s)
either use task.setParameterValue(parmname, parmvalue)
task.setParameterValues(parmmap);
IGetParameterDefinitionTask is used to get parameter info, primarily to
build user entry dialogs.
Jason
Re: Setting parameters via API [message #294462 is a reply to message #294455] Fri, 25 January 2008 08:46 Go to previous message
Thanks! I'll have a look in that direction.
(A "BIRT Cookbook" would be wonderful. There's a big contrast between the
helpfulness of the report design tutorials and the bare API listings in the
programming sections of Eclipse help books.)
Re: Setting parameters via API [message #319731 is a reply to message #294449] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #319739 is a reply to message #294455] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #320123 is a reply to message #294449] Thu, 24 January 2008 18:13 Go to previous message
Phillip,
Jason
Re: Setting parameters via API [message #320130 is a reply to message #294455] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #337115 is a reply to message #319731] Fri, 25 January 2008 08:46 Go to previous message
Re: Setting parameters via API [message #337190 is a reply to message #320123] Fri, 25 January 2008 08:46 Go to previous message
Previous Topic:Setting parameters via API
Next Topic:Setting parameters via API
Current Time: Tue Sep 16 04:57:30 EDT 2025
Powered by FUDForum. Page generated in 0.06179 seconds
