| Bundle JRE from headless pde build [message #29492] |
Mon, 27 October 2008 11:56  |
Hi Guys,
Does anyone have any pointers how to do this? I am trying to
include the jre alongwith my product build and need a way to include the
jre. Any insights will be appreciated.
ab
| Re: Bundle JRE from headless pde build [message #30351 is a reply to message #30209] |
Thu, 30 October 2008 13:06  |
I think you will need to copy a build.properties into the feature using
customTargets.xml and the preGenerate ant task. Something like this
could work:
customTargets.xml:
<target name="preGenerate">
<echo message="root.folder.jre=absolute:C:/java....\n"
file=" ${buildDirectory}/features/org.eclipse.pde.build.container.f eature/build.properties "/>
</target>
Abhishek Misra wrote:
> Thanks Andrew, our product is based on plugins and we are not on 3.4. Is
> there something similar to generatedBuildProperties in older versions of
> eclipse?
> ab
> Andrew Niefer wrote:
>> You can include a JRE in the same way you include any other root files.
>> Include a feature in your product, and that feature should define root
>> properties in its build.properties file. This is how the UI supports
>> bundling a JRE on export. (Features can be build-time only by having
>> an empty bin.includes property).
>> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/tasks/pde_rootfiles.htm
>> In particular, the UI uses the "root.folder.<subfolder>" properties
>> which copy the indicated files into the specified subfolder of your
>> product:
>> root.folder.jre=absolute:C:/dev/java/jre
>> or if you have multiple configurations:
>> root.win32.win32.x86.folder.jre=absolute:C:/dev/java/windows /jre
>> root.gtk.linux.x86.folder.jre=absolute:C:/dev/java/linux/jre
>> If your product is based on plugins instead of features, in 3.4 you
>> can add these root properties to the automatically generated container
>> feature that is used by the build. In your build configuration, set
>> the property "generatedBuildProperties" to point to a build.properties
>> file to use with the generated feature.
>> -Andrew
>>> Hi Guys,
>>> the jre. Any insights will be appreciated.
>>> Thanks,
>>> ab
| Re: Bundle JRE from headless pde build [message #583745 is a reply to message #29492] |
Tue, 28 October 2008 11:32  |
bundling a JRE on export. (Features can be build-time only by having an
which copy the indicated files into the specified subfolder of your product:
If your product is based on plugins instead of features, in 3.4 you can
feature that is used by the build. In your build configuration, set the
property "generatedBuildProperties" to point to a build.properties file
-Andrew
> Hi Guys,
> ab
| Re: Bundle JRE from headless pde build [message #583837 is a reply to message #30013] |
Wed, 29 October 2008 16:35  |
eclipse?
ab
> product:
> -Andrew
>> Hi Guys,
>> Thanks,
>> ab
| Re: Bundle JRE from headless pde build [message #583901 is a reply to message #30209] |
could work:
customTargets.xml:
</target>
> eclipse?
> ab
>> product:
>> -Andrew
>>> Hi Guys,
>>> Thanks,
>>> ab
FUDForum. Page generated in 0.29255 seconds
