Home » Modeling » M2T (model-to-text transformation) » Acceleo Builder error encountered during build: java.util.ConcurrentModificationException(Acceleo Builder error encountered during build: java.util.ConcurrentModificationException)
Acceleo Builder error encountered during build: java.util.ConcurrentModificationException [message #1576670] Wed, 21 January 2015 07:56 Go to next message
Hi, I am currently encountering an Acceleo Builder error whenever I build or clean then build in eclipse. I get the following error as follows:
Errors occurred during the build.
Errors running builder 'Acceleo Builder' on project '<project.name>'.
I am using the following:
Eclipse Kepler Release 2
Acceleo/Acceleo SDK 3.4.2
I have already tried excluding the *.mtl files in the build using resource filters in eclipse, but this has not solved anything.
Thanks in advance.
Re: Acceleo Builder error encountered during build: java.util.ConcurrentModificationException [message #1577396 is a reply to message #1576670] Wed, 21 January 2015 16:56 Go to previous messageGo to next message
I saw similar recently, but since I no longer use Acceleo, I just
uninstalled. Looks like the still unresolved
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372052.
One possible solution that helped me with some of my Acceleo headaches
was to make sure that I did not have org.eclipse.ocl.ecore checked out
as a project.
Ed Willink
> Thanks in advance.
Re: Acceleo Builder error encountered during build: java.util.ConcurrentModificationException [message #1626005 is a reply to message #1576670] Fri, 20 February 2015 14:27 Go to previous message
This was resolved in Luna Smile
Previous Topic:[Acceleo] Removing duplicate in collection
Next Topic:SysML activity diagram output pins.
Current Time: Mon Nov 03 22:11:21 EST 2025
Powered by FUDForum. Page generated in 0.04973 seconds
