Home » Eclipse Projects » Eclipse Platform » howto (possibly remotely) debug into a custom Ant task's Java code?
| howto (possibly remotely) debug into a custom Ant task's Java code? [message #292618] |
Fri, 07 October 2005 22:20  |
I'm running 3.2-M2 on winXP under java 5 (but not using any 1.5- or
even 1.4-specific features) and writing a custom Ant task. It's not
working :-( when I run the Ant script that taskdefs and uses my task,
I get spew in the Console. How to debug it? Unless I'm missing
something, the Ant debugger does not support this: see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=112010
> support and document debugging into custom-task Java code
I find nothing about debugging Ant or the Ant debugger in Help>Help
Contents, so I googled and found
https://bugs.eclipse.org/bugs/show_bug.cgi?id=24130
> Ability to execute ANT tasks in the Java Debugger so I can debug the
> ANT task java code itself.
> Additional Comment #4 From Darin Swanson 2003-07-29 10:09
> You can do this with a little bit of work.
> You can use the Runtime-workbench launch configuration to self-host
> an Eclipse target or you can launch an Eclipse session in debug mode
> such that another Eclipse session can remote debug any Ant task that
> you run.
> Gilles, what exactly are you attempting to do?
> Additional Comment #5 From Gilles Scokart 2003-07-29 10:24
> I have writen my own ANT task, and I want to debug his code when
> called from an ANT script.
> I'm sure to understand your suggestion. I have tried to launch a
> separate workbench from the Debug... menu, but when I specify my
> "normal" workspace data, the workbench doen't start. Do I have to
> use a separate worspace data and rewrite the content of the project
> that contains the ant script?
> I have also seen options in the Common tab of the "Ant launcher".
> But I don't know what to put in the "Type of launch configuration",
> and the "Debug Mode" drop down is disabled.
> Could you explain me or give a link to some documentation.
> Additional Comment #6 From Darin Swanson 2003-07-29 13:46
> I am the documentation currently :-)
> You cannot have two Eclipse sessions working on the same workspace
> at the same time. You can import an existing project from one
> workspace to another using File >Import> Existing Project into
> Workspace.
> I would try this:
> launch a run-time workbench launch configuration on a new workspace
> target
> point it to a new workspace.
I create a fresh dir, and create a runconfig pointing to that
Location, taking all other defaults.
> import your project(s) as outlined above.
From the runbench, File>Import...>Existing Projects, and point back to
my devbench's project. The imported project builds.
> Run your Ant builds and debug your Ant tasks using the host Eclipse
> session.
That part I don't understand. I see the Help topic
Java Development UG>Tasks>Running and Debugging>Remote debugging>
Using the remote Java application launch configuration
> The Remote Java Application launch configuration should be used when
> debugging an application that is running on a remote VM. Since the
> application is started on the remote system, the launch
> configuration does not specify the usual information about the JRE,
> program arguments, or VM arguments. Instead, information about
> connecting to the application is supplied.
> To create a Remote Java Application launch configuration, do the
> following:
> Select Run >Debug....from the workbench menu bar (or Debug... from
> the drop-down menu on the Debug tool bar button) to show the launch
> configuration dialog.
> Select the Remote Java Application in the list of configuration
> types on the left.
> Click the New button. A new remote launch configuration is created
> and three tabs are shown: Connect, Source, and Common.
> In the Project field of the Connect tab, type or browse to select
> the project to use as a reference for the launch (for source
> lookup). A project does not need to be specified.
.... but I set it to my project.
> In the Host field of the Connect tab, type the IP address or domain
> name of the host where the Java program is running.
> If the program is running on the same machine as the workbench, type
> localhost.
.... is the default.
> In the Port field of the Connect tab, type the port where the remote
> VM is accepting connections. Generally, this port is specified when
> the remote VM is launched.
Take default=8000. I.e. I only set project=my project (and the config
name) taking all other defaults.
> The Allow termination of remote VM flag is a toggle that determines
> whether the Terminate command is enabled in the debugger. Select
> this option if you want to be able to terminate the VM to which you
> are connecting.
> Click Debug. The launch attempts to connect to a VM at the specified
> address and port, and the result is displayed in the Debug view. If
> the launcher is unable to connect to a VM at the specified address,
> an error message appears.
I get "Failed to connect to remote VM."
What do I need to do to in order to remote debug? E.g. to make the
launched Eclipse accept the connection?
Or is there a better way to debug my ant task?
Feel free to forward, or to reply directly to me (as well as the
newsgroup), and TIA.
| Re: howto (possibly remotely) debug into a custom Ant task's Java code? [message #292626 is a reply to message #292618] |
Sat, 08 October 2005 23:14   |
Wow...so much of my own words :-)
In 3.2:
Set to run your Ant build in a separate JRE
Set the VM args on the JRE tab of the Ant launch configuration to enable
remote debugging.
-Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,server=
y,suspend=y,address=8000
Start your Ant build
Launch the remote debug session
HTH
Darins
"Tom Roche" <tlroche@us.ibm.com> wrote in message
news:di7ae8$d01$1@news.eclipse.org...
> > you run.
> > Workspace.
> > I would try this:
> > target
> > session.
> > following:
> > types on the left.
> > localhost.
> ... is the default.
> > are connecting.
Current Time: Fri Oct 31 21:26:21 EDT 2025
Powered by FUDForum. Page generated in 0.05844 seconds
