Home » Eclipse Projects » Eclipse Platform » IPropertySource - NoClassDefFoundError
IPropertySource - NoClassDefFoundError [message #292501] Thu, 06 October 2005 17:19 Go to next message
We are trying to implement a properties page on one of our model objects.
The model object is implementing IAdaptable. The gett adapter code (shown
here)
public Object getAdapter(Class adapter) {
if ( adapter.equals(IPropertySource.class) )
return new PropertySourceAdapter(this);
else
return super.getAdapter(adapter);
I getting called but is failing with a class def not found exception.
Here is the stacktrace.
!ENTRY org.eclipse.jface 4 2 2005-10-06 16:07:58.304
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError:
org.eclipse.ui.views.properties.IPropertySource
We have verified that the org.eclipse.ui.views plugin is included in the
project and is available, as we can load the Properties View. Has anyone
seen this issue before ?
Here are the specs on the machine
Windows XP Pro build 5.1.2600.2622
jre1.5.0_04 / 1.4.2_08
Eclipse 3.1 buildId=I20050627-1435
Re: IPropertySource - NoClassDefFoundError [message #292509 is a reply to message #292501] Thu, 06 October 2005 20:12 Go to previous messageGo to next message
add org.eclipse.ui.views plugin in dependencies
Peco
Dave Erickson wrote:
> here)
> else
> !STACK 0
Re: IPropertySource - NoClassDefFoundError [message #292511 is a reply to message #292509] Thu, 06 October 2005 18:49 Go to previous messageGo to next message
We already have the dependency set, and have verified that the
org.eclipse.ui.views jar file is in the plugins directory. We can load
the properties views provided by the plugin, but when we try and use
IPropertySuorce it dies with the noclassdef error.
Re: IPropertySource - NoClassDefFoundError [message #292512 is a reply to message #292501] Thu, 06 October 2005 18:53 Go to previous messageGo to next message
Could this be related to the manifest file ?? I have posted it here
Manifest-Version: 1.0
Bundle-Name: XXXX Main Plugin
Bundle-SymbolicName: com.xxx.xxx.rcp.main; singleton=true
Bundle-Version: 1.0.0
Bundle-ClassPath: log4j.jar,
commons-logging.jar,
j2ee.jar,
xsdbeans.jar,
XXX_COMMON.jar
Bundle-Activator: com.xxx.xxx.client.rcp.plugin.MainPlugin
Bundle-Vendor: XXXXXXX
Bundle-Localization: plugin
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.ui.views,
org.eclipse.help,
org.eclipse.osgi.services,
org.eclipse.ui.forms,
org.eclipse.ui.workbench.texteditor,
org.eclipse.core.resources
Eclipse-AutoStart: true
Re: IPropertySource - NoClassDefFoundError [message #292520 is a reply to message #292511] Thu, 06 October 2005 22:48 Go to previous messageGo to next message
you don't include any dependency plugin (org.eclipse.jface or like)
Re: IPropertySource - NoClassDefFoundError [message #1750443 is a reply to message #292501] Wed, 21 December 2016 02:16 Go to previous message
I have also faced the exact problem in my GEF plugin.I have added the "org.eclipse.ui.views" in my dependencies in plugin.xml
Previous Topic:Avoid Tooltips on Menu Items
Next Topic:How to find old source jar?
Current Time: Fri Sep 26 00:31:47 EDT 2025
Powered by FUDForum. Page generated in 0.08276 seconds
