Home » Modeling » TMF (Xtext) » How to reimport xtext project(Reimport project problems)
How to reimport xtext project [message #1571771] Sun, 18 January 2015 16:13 Go to next message
Hi all.
I use following eclipse
Eclipse for RCP and RAP Developers
Version: Luna Release (4.4.0)
Build id: 20140612-0600
When I reimport xtext project, can do it only for main project. But, eclipse think that UI and test isn't project. So I can't import it.
How I can to solve this problem?
Vladimir
Re: How to reimport xtext project [message #1571808 is a reply to message #1571771] Sun, 18 January 2015 16:41 Go to previous messageGo to next message
what do you exaclty do when reimporting? what is the error you get (if any)
Re: How to reimport xtext project [message #1571881 is a reply to message #1571808] Sun, 18 January 2015 17:42 Go to previous messageGo to next message
I export my projects as following: file>import>Existing Project Into Workspace. Rootine procedure for the importing. I haven't see any error, but eclipse see as project only org.casualintellect.editor, and don't see as projects org.casualintellect.editor.ui and org.casualintellect.editor.test
Re: How to reimport xtext project [message #1572461 is a reply to message #1571881] Mon, 19 January 2015 01:35 Go to previous messageGo to next message
and how did you do the export? it looks your projects miss the .project (and maybe .classpath) files
Re: How to reimport xtext project [message #1573669 is a reply to message #1572461] Mon, 19 January 2015 16:56 Go to previous messageGo to next message
Well, I just close my projects, then delete them(without deleting from the disk of course), then open my projects again. You say true, there aren't .project files. But why it's happens? You see, when I do the same with any other type of the projects, there aren't such problems
Re: How to reimport xtext project [message #1574197 is a reply to message #1573669] Tue, 20 January 2015 00:07 Go to previous message
I don't know. Can you retry that with a newly created project?
Previous Topic:Error "Cyclic linking detected" in editor window
Next Topic:Sharing Xtext project at Github, how to do it?
Current Time: Sat Nov 08 12:16:59 EST 2025
Powered by FUDForum. Page generated in 0.03768 seconds
