| How to run latest nightly? [message #29278] | Fri, 15 June 2007 16:18  |  |
| Eclipse User  |  |  |  |  | I'm sure this is a dumb question, but I've downloaded the latest nightly and extracted it into my eclipse 3.2.2. It's complaining about needing WST 2.0.0. I've searched for it, but can't find it. Is this something that's only available in the 3.3 release of Eclipse? Is it safe to run the latest nightly on the 3.3 release?
 Any pointers would be appreciated.
 Adam.
 Adam Randall                                  adam@lockdownnetworks.com
 Senior Software Engineer                      (866) 844-8080
 Lockdown Networks, Inc.
| Re: How to run latest nightly? [message #29391 is a reply to message #29317] | Fri, 15 June 2007 19:28   |  |
| Eclipse User  |  |  |  |  | On Sat, 16 Jun 2007 00:17:07 +0200 Iavor Raytchev <pobox@verysmall.org> wrote:
 > > Regards,
 > > Adam.
 > I'm having exactly the same problem and posted a question, but there has
 > been no reply so far.
 > Good to hear that you have the same problem - was wondering if it is
 > just something on my workstation.
 > Would be good to hear if you find out something.
 > Iavor
 I downloaded and installed Eclipse 3.3R4 and installed the WST 2.0.0 from the Europa repository. After that, I installed the latest nightly of the PDT, which was not from the remote site but from the .zip file. After that, everything came up correctly. Subclipse also worked after I installed it, so that was a plus.
 All in all, it's working, though syntax checking seems to be busted (who needs that? we all write perfect code, right? :)
 I believe the Remote Archive url will only install the 0.7 releases, and not the 1.0.0 releases. YMMV.
 Eclipse 3.3R4 (from the .tar.gz)
 PDT 1.0.0 (N20070614)
 Ubuntu Linux 7.04
 JRE 1.6
 Adam.
| Re: How to run latest nightly? [message #29428 is a reply to message #29391] | Fri, 15 June 2007 19:45  |  |
| Eclipse User  |  |  |  |  | Originally posted by: pobox.verysmall.org
 > Ubuntu Linux 7.04
 > JRE 1.6
 > Adam.
 Yes - I found out as well that the Update Manager has some weird
 internal logic... So when PDT complains about something - I just get the
 ..zip and unzip it in eclipse/.
 All fine so far.
 And yeah - I'm would be happy if the syntax checking is busted... Spent
 many hours in the past to try to switch it off ;)
 Iavor.
FUDForum. Page generated in 0.05693 seconds
