Home » Eclipse Projects » Eclipse Platform » Using Default Java Compiler to Build
Using Default Java Compiler to Build [message #291936] Tue, 27 September 2005 10:51 Go to next message
Originally posted by: Krishnan.Muthuswamy.gmail.com
Even though I have set up default JDK to buid and compile Java Programs
(by going into Window -> Preferences -> Java -> Installed JRE, Eclipse
seems to be using its internal compiler to build. Is this true? The reason
why I am feeling this way is because, when I do remote debugging of my
J2EE application (built separately outside of Eclipse using Ant Scripts) I
can see the debugger jumping lines in the code while stepping through.
While most of the time this is not a big deal, the problem is when I have
the automatic build turned on, Eclipse and Ant Scripts sharing the classes
(bin folder) folder, creates ClassFormatError in the J2EE application.
This happens because Classes created by Eclipse are different from classes
generated by the default JRE Compiler which is used by my Ant Scripts.
Has anyone come across this issue?
Cheers
Krish
Re: Using Default Java Compiler to Build [message #292173 is a reply to message #291936] Thu, 29 September 2005 18:06 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
Krishnan Muthuswamy wrote:
> reason why I am feeling this way is because, when I do remote debugging
> of my J2EE application (built separately outside of Eclipse using Ant
> Scripts) I can see the debugger jumping lines in the code while stepping
> through.
> have the automatic build turned on, Eclipse and Ant Scripts sharing the
> classes (bin folder) folder, creates ClassFormatError in the J2EE
> application. This happens because Classes created by Eclipse are
> different from classes generated by the default JRE Compiler which is
> Has anyone come across this issue? Cheers
> Krish
I doubt the problem is caused by having Eclipse build to the same
location as an Ant script and javac - I've done that on several projects
without any such problems.
One thing to make sure is that the Java > Compiler preferences in
Eclipse specify a Java Compliance setting that agrees with the JVM that
you are using to run your application server.
Check that and report back the details.
HTH,
Eric
Re: Using Default Java Compiler to Build [message #292203 is a reply to message #291936] Fri, 30 September 2005 12:26 Go to previous message
Originally posted by: automatic.javalobby.org
The debugger is unrelated to the compiler used to build the code. The compiled code (with debug information) reports when it goes past a different line, and Eclipse's debugger follows the cursor forward.
You are probably better off setting up Ant to use a different directory to the one that Eclipse uses for its compiled output. We've got a mechanism that does similar here, where we use Eclipse to do development work (and using an Eclipse-specific 'Build' folder) with an automated build (using a 'target' folder).
Previous Topic:What is the trick to adding submenus to an IMenuManager?
Next Topic:SaveParticipant: "Worker thread ended job ..."
Current Time: Wed Nov 05 14:38:11 EST 2025
Powered by FUDForum. Page generated in 0.03551 seconds
