Re: Making "light" package releases [message #270 is a reply to message #264] |
Wed, 08 October 2008 15:02 |
Dave Russo Messages: 172 Registered: July 2009 |
Ramsey Harris wrote:
> When I use Pkg.attrs.exportAll = true; I still get all the generated
> libraries built by my package. Since these are known to be generated, I
> was not expecting them in the release. I'm using XDCtools 3.10.02.
Right, exportAll only _adds_ files to what has already been specified in
your build script. It's used to pickup "legacy/internal" headers
documentation files, etc.
If you only want sources and no libraries you can create multiple
releases (say src_only and full) and when you add libraries (via
addLibrary()), you need to explicitly exclude the src_only release using
the optional releases array.
Pkg.addLibrary("foo", targ, {releases: [full]});
Another way to eliminate libraries from a release is to supply a
"release script" which simply removes them. In this case, you again
create two releases and the _only_ difference is that one of the
releases has a release script that simply removes some/all libraries.
Although it is possible to get a "source only" release, it's painful;
you need to use fairly advanced features for what should be simple,
especially since it is a fairly common request. We do have an
outstanding feature request to provide yet another optional attribute to
releases, say exportSrcOnly, that would make it easy to create such a
release.
FUDForum. Page generated in 0.04331 seconds
