copy and paste is very slow in Java Editor [message #290615] |
Sat, 27 August 2005 12:37  |
Originally posted by: k-rad.excite.com
I've had this problem with Eclipse for some time, but it seems to be getting
worse. Copy/paste operations on text in the Java editor take forever and
sometimes freeze the whole program for minutes on end. I have this problem
on two different computers. One has a vanilla 3.1.0 installation (had 3.0.1
with the same problem and upgraded the other day but the problem remains)
and the other has Together-Eclipse.
Basically, I open a project, open a Java file using Navigator, select some
text and hit ctrl-c. Sometimes it takes 1 seconds, more often 10, and
sometimes it sits there for 5 minutes.
Has anyone seen this before? Sorry if this has been asked, but I searched
the newsgroups and bug database and I couldn't find anything except
something related where the solution was to disable Folding which I have
done.
Konrad
Re: copy and paste is very slow in Java Editor [message #290622 is a reply to message #290615] |
Sat, 27 August 2005 21:19   |
> done.
I'd highly recommend filing a bug, maybe against Platform > SWT.
Here are some thing you should check:
- Is it only in the Java editor, or can you reproduce it in the Text
editor?
- Do you use any desktop sharing applications, such as VNC, synergy2,
x2x, or anything like that?
- What platform are you on? If Linux, do you have any clipboard
manager applications running, such as KDE's Klipper?
-Billy
Re: copy and paste is very slow in Java Editor [message #290645 is a reply to message #290622] |
Mon, 29 August 2005 06:53  |
Originally posted by: daniel.megert.gmx.net
Billy Biggs wrote:
>> getting
>> problem
>> 3.0.1
>> remains)
>> some
>> searched
>> done.
> editor?
Please also make a stack trace when this happens again and attach the
trace to the bug report. What OS are you using?
Dani
> -Billy
FUDForum. Page generated in 0.02405 seconds
