Home » Eclipse Projects » Mylyn » About Commit Comment Template
About Commit Comment Template [message #1563543] Wed, 14 January 2015 03:57 Go to next message
I wonder why the "task" in "Commit Comment Template" is not always the activated task currently?
When I activate task A and create file A, and commit file A using subclipse, then the "task" in "Commit Comment Template" is always task A.
So when do the "task" in "Commit Comment Template" change?
Best wishes.
Re: About Commit Comment Template [message #1563552 is a reply to message #1563543] Wed, 14 January 2015 04:02 Go to previous messageGo to next message
Ok, I found the "ressign Changes to" function in "Synchronize" view. Thanks for your tutorial.
Re: About Commit Comment Template [message #1564219 is a reply to message #1563552] Wed, 14 January 2015 12:21 Go to previous message
The commit message refers to the task that was active when the file was changed. That way you can switch between multiple tasks and later commit only the changes for a specific task.
Sam
Previous Topic:Atlassian Jira Connector Problem
Next Topic:Unable to install
Current Time: Wed Nov 05 16:45:41 EST 2025
Powered by FUDForum. Page generated in 0.03619 seconds
