Home » Eclipse Projects » Eclipse Platform » Open multiple files with an editor plug-in
| Open multiple files with an editor plug-in [message #289563] |
Mon, 08 August 2005 07:33  |
Originally posted by: annagaspar.gmail.com
I'd like to make an editor that could open multiple files at the same time.
I don't know how to make that, because an editor is associated with only
one IEditorInput, so one editor only can modify one file.
Ana
| Re: Open multiple files with an editor plug-in [message #289607 is a reply to message #289599] |
Mon, 08 August 2005 15:22   |
Originally posted by: sunil_kamath.nohotspammail.com
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:dd829b$3mt$1@news.eclipse.org...
> Sunil Kamath wrote:
>> "Ana Gaspar" <annagaspar@gmail.com> wrote in message
>> news:dd7fur$9d8$1@news.eclipse.org...
>>>Hello,
>>>time.
>>>Thanks,
>>>Ana
>> org.eclipse.ui.part.MultiEditor
>> Sunil
> Better to use org.eclipse.ui.part.MultiPageEditorPart ... if you create a
> new plugin project and use the multi-editor template, you'll even get an
> example.
AFAIK, the MultiPageEditorPart is for editing one file in multiple pages.
MultiEditor, OTOH, is for editing multiple files, each on a single page.
MultiEditorInput contains arrays of editor ids and editor inputs.
Sunil
| Re: Open multiple files with an editor plug-in [message #289614 is a reply to message #289607] |
Tue, 09 August 2005 03:00   |
>>>>Hello,
>>>>time.
>>>>Thanks,
>>>>Ana
>>>Sunil
>>example.
> Sunil
Well thanks to all, i wish have an example of MultiEditor plug-in, any
know where can I get one?
| Re: Open multiple files with an editor plug-in [message #289631 is a reply to message #289607] |
Tue, 09 August 2005 09:22   |
>>example.
> Sunil
I think for the most part you need to use a specific action to open a
MultiEditor ... I don't see why that wouldn't work with handing a
MultiEditorInput to a MultiPageEditorPart.
Then your createPages() could get your EditorInput, check to see if it's
a MultiEditorInput, and extract the inner editor IDs and editor inputs,
and then use MultiPageEditorPart#addPage(IEditorPart editor,
IEditorInput input).
You would have to instantiate the EditorParts yourself, but there must
be a way to get from the ID to the IEditorPart ... maybe using
executable extensions?
MultiEditor is much better if you want to show 2 editors side by side,
like the TiledEditor example from the bug report you mentioned.
MultiPageEditorPart can open the multiple editors, but in a CTabFolder.
Later,
PW
| Re: Open multiple files with an editor plug-in [message #289632 is a reply to message #289629] |
Tue, 09 August 2005 09:31   |
news:dda98b$l3c$1@news.eclipse.org...
>> news:dd9k9v$qf6$1@news.eclipse.org...
>> [snip]
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=42641
>> The bad news is that when the editor lifecycle was reworked for 3.1, they
>> broke MultiEditor.
>> So you have to wait until 3.1.1 or 3.2 before it gets fixed.
>> Sunil
> Then, is impossible to make an plugin application to manage differents
> files?
> I'm trying to make an editor plugin whose funcionality is similar to
> XMLSpy, where you can open different files at time.
You could probably try faking it with MultiPageEditor.
Create a custom action to open the MultiPageEditor:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(editorInput,editorId);
However, instead of the regular IFileEditorInput, create a MultiEditorInput
instead.
Then, within your editor setInput, when you create the pages, take the array
of editor inputs from the MultiEditorInput and use that to create each page.
Sunil
| Re: Open multiple files with an editor plug-in [message #289721 is a reply to message #289631] |
Wed, 10 August 2005 05:46   |
>>> create a new plugin project and use the multi-editor template, you'll
>>> even get an example.
>> Sunil
> Later,
> PW
Ok, I create each page with different IEditorInput and IEditorPart,but
now my problem is how to obtain the differents IEditorInput to create
the MultiEditorInput?
| Re: Open multiple files with an editor plug-in [message #289727 is a reply to message #289631] |
Wed, 10 August 2005 07:41  |
You need to create your own action delegate. Check out the bug that
Sunil suggested earlier ... the tiled editor example has an
OpenActionDelegate that can create a MultiEditorInput for the files
selected in the package explorer.
Later,
PW
Current Time: Wed Nov 05 14:38:36 EST 2025
Powered by FUDForum. Page generated in 0.05765 seconds
