Home » Eclipse Projects » Eclipse Platform » Jboss IDE not running
Jboss IDE not running [message #288510] Tue, 19 July 2005 10:39 Go to next message
Originally posted by: nospam99.gmx.de
I installed JBOSS IDE with Find & Install.
Eclipse 3.1 RC4
JBOSS IDE 1,4,1.e31-jre15
Restarted with -clean 1 time.
When I want to create a new configuration, I get "An error has occurred. See
error log for more details."
Which errorlog? I can
Re: Jboss IDE not running [message #288518 is a reply to message #288510] Tue, 19 July 2005 11:08 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
Heiko Kramp wrote:
> Hello,
> Eclipse 3.1 RC4
> Which errorlog? I can´t find one.
> What could be the problem?
> I´m grateful for any suggestions.
You can open the error log under Window -> Show View -> Error Log or
simply look in the log file in your workspace
<yourworkspace_directory>/.metadata/.log
BTW is Jboss IDE actually released for Eclipse 3.1? They had a problem
with it since they use internal packages which broke their implementation.
Stefan
Re: Jboss IDE not running [message #288600 is a reply to message #288518] Wed, 20 July 2005 04:00 Go to previous messageGo to next message
I found the errorlog now. Thanks.
JBoss IDE is released for 3.1.
But i see that your presumtion is right:
Snip from the errorlog:
org.osgi.framework.BundleException: Exception in
org.jboss.ide.eclipse.deployer.ui.DeployerUIPlugin.start() of bundle
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/ui/dialogs/StatusDialog
I don
Re: Jboss IDE not running [message #288604 is a reply to message #288600] Wed, 20 July 2005 04:08 Go to previous messageGo to next message
> I don´t understand this error, cause the IDE is released for 3.1 and i got
> it with search and install from eclipse which should automatically make a
> version check.
> Any suggestions?
> "Stefan Langer" <eclipse@bettsockentraeger.de> schrieb im Newsbeitrag
> news:dbj50p$slj$1@news.eclipse.org...
>>Heiko Kramp wrote:
>>>Hello,
>>>Eclipse 3.1 RC4
>>>See error log for more details."
>>Regards
>>Stefan
Your best bet is to go to JBoss and ask there.
Stefan
Re: Jboss IDE not running [message #288642 is a reply to message #288600] Wed, 20 July 2005 11:27 Go to previous message
> version check.
> Any suggestions?
See response in the thread titled "JBoss Anyone?" where a JBoss
developer cleared things up (they just released a new version of JBoss
IDE that is 3.1 compatible)
HTH,
Eric
Previous Topic:How to access file with a plugin on Windows/Linux platform ?
Next Topic:When do the public builds start again?
Current Time: Sat Jul 26 05:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.50836 seconds
