How to run two clients with parallel processes in Eclipse? [message #1556544] |
Sat, 10 January 2015 06:37  |
Good day.
I googled, but could not find the exact answer.
I created a simple EJB project in eclipse. I created a session full bean, added a business method, then created a simple java console client, deployed EJB project and started the server.
Then I run the client.
Is it possibly to run the second instance(process) to the same client in eclipse?
I would like to start running two processes for a single client app simultaneously.
I guess it must be something simple, but I can't figure it out.
Re: How to run two clients with parallel processes in Eclipse? [message #1558751 is a reply to message #1556544] |
Sun, 11 January 2015 12:36  |
On 01/11/2015 11:06 AM, Alexey Lekomtsev wrote:
> Good day.
> eclipse?
> simultaneously.
Simply select the client launch from the Run menu while the first client
is running. This will start a new Java process. You can kick off as
many instances of a process as your system will allow.
Note that if the processes use a common resource, you will need to
change values between instances you launch. For example, if the process
opens a listen socket, you will have to use a different port number for
each process. This isn't an Eclipse limitation, it is a system
limitation. Only one process is allowed to listen on a port at one time.
FUDForum. Page generated in 0.07264 seconds
