Home » Eclipse Projects » Eclipse Platform » Use Eclipse for your own plug-in enabled programs
Use Eclipse for your own plug-in enabled programs [message #28754] Thu, 08 May 2003 06:08 Go to next message
I'm cheking out Eclipse and SWT/JFace and I wonder: Can I use the
Eclipse platform to create my own plug-in enabled applications? I've
read that even the Worbench GUI is a plug-in, so to my opinion I can use
the "naked" eclipse platform and create my own GUI on top of it ( and
other plug-ins ofcourse).
Does this GUI always have to be in SWT or can it be Swing to?
Is there a "naked" eclipse framework available or do I have to strip it
myself.
What will be the impact on the license? Can I sell my plug-ins without
having to distribute the source code, if I don't addapt the Eclipse
framework, but only create things on top of it?
thanks
Re: Use Eclipse for your own plug-in enabled programs [message #28760 is a reply to message #28754] Thu, 08 May 2003 07:56 Go to previous messageGo to next message
> myself.
There is nothing available, you'll have to strip it down yourself.
Basically you'll need startup.jar, boot, runtime, xerces. This will bring
you the pluggability.
There is no restriction. None of the plugins previously listed relies on
SWT.
PaScaL
Re: Use Eclipse for your own plug-in enabled programs [message #28764 is a reply to message #28760] Thu, 08 May 2003 08:23 Go to previous messageGo to next message
Are there plans for a stripped version?
Re: Use Eclipse for your own plug-in enabled programs [message #28767 is a reply to message #28764] Thu, 08 May 2003 08:28 Go to previous messageGo to next message
Yes, the 3.0 version will offer also a stripped version (afaik).
Stelian Iancu
Linux registered user 287835
Re: Use Eclipse for your own plug-in enabled programs [message #28780 is a reply to message #28764] Thu, 08 May 2003 08:37 Go to previous messageGo to next message
Originally posted by: dhill.eweb-service.com
I am trying to strip it down, does anyone have a ver 2.x stripped down
or a plugin structure that is needed to do this.,
On Thu, 08 May 2003 14:23:31 +0200, Ronald Vanschoren
Re: Use Eclipse for your own plug-in enabled programs [message #28788 is a reply to message #28764] Thu, 08 May 2003 10:06 Go to previous messageGo to next message
Originally posted by: faust.acm.org
http://www.eclipse.org/eclipse/development/eclipse_project_p lan_2_2.html
You may be interested in the item, "Enable Eclipse to be used as a general
purpose application framework."
Randy
"Ronald Vanschoren" <ronald.vanschoren@wol.be> wrote in message
news:b9di72$pj2$1@rogue.oti.com...
Re: Use Eclipse for your own plug-in enabled programs [message #28838 is a reply to message #28754] Thu, 08 May 2003 14:51 Go to previous messageGo to next message
Ronald
Most of Eclipse is distributed under the Common Public License. Some
portions are distributed under other licenses. You should read the
notice.html and the about.htmls in each of the plug-ins, and all referenced
documents (e.g. cpl-v10.html) to get the full story. You may also wish to
read the Eclipse Legal and IBM CPL FAQs - there are links on the "Legal
Stuff" section of the Eclipse.org web site. You should find that these
answer your questions. If you are still in doubt after reading all the
documentations then I suggest you post here again.
Adrian
Re: Use Eclipse for your own plug-in enabled programs [message #29551 is a reply to message #28754] Fri, 09 May 2003 00:30 Go to previous messageGo to next message
See
http://www.eclipse.org/newsportal/article.php3?id=396&gr oup=eclipse.platform
for what I've done so far on creating a Base Non-IDE Application Using the
Workbench
Re: Use Eclipse for your own plug-in enabled programs [message #29650 is a reply to message #29551] Fri, 09 May 2003 07:53 Go to previous messageGo to next message
This is good but even better would be a jar to overlay the file system
with the require files.
On Fri, 9 May 2003 04:30:18 +0000 (UTC), destberg1@earthlink.net (Don
>See
>Workbench
Re: Use Eclipse for your own plug-in enabled programs [message #29664 is a reply to message #28754] Fri, 09 May 2003 11:00 Go to previous message
I've been reading a bit and I think it's possible to create an
IPlatformRunnable and start it, without the workbench beeing loaded. Has
anyone tried that? Then ofcourse all the classes of the workbench etc
are still there, but they are never loaded.. I think...
> myself.
> thanks
Previous Topic:bug in help doc?
Next Topic:Showing text in the Console view
Current Time: Tue Aug 19 20:04:38 EDT 2025
Powered by FUDForum. Page generated in 0.04641 seconds
