Home » Eclipse Projects » Eclipse Platform » project nature
project nature [message #28750] Thu, 08 May 2003 04:23 Go to next message
Originally posted by: bhavnad.noida.hcltech.com
hi,
i've created a plugin with a builder extension & a nature to associate
that builder to a project. when a run it as workbench, the plugin registry
shows my plugin but the error log shows the following error:
Error Thu May 08 13:51:21 IST 2003 Plug-in
"org.eclipse.examples.helloworld" was unable to instantiate class
"org.eclipse.examples.helloworld.MyNature".
java.lang.NoSuchMethodException
at java.lang.Class.getConstructor0(Class.java:1755)
at java.lang.Class.getConstructor(Class.java:990)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:701)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:301)
at org.eclipse.ui.internal.Workbench$15.run(Workbench.java:1325 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:889)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1334 )
at java.lang.Thread.run(Thread.java:536)
Is any specific constructor requirde for the class implementing
IProjectNature?
Re: project nature [message #28795 is a reply to message #28750] Thu, 08 May 2003 10:26 Go to previous messageGo to next message
exquisitus wrote:
> hi,
> at
> at
> at
> at
> IProjectNature?
At this line it is trying to instantiate your PluginClass, not your
PluginNature. So you specified your nature in the wrong place.
Thanks, Rich Kulp
Re: project nature [message #29629 is a reply to message #28795] Fri, 09 May 2003 05:27 Go to previous messageGo to next message
Richard L. Kulp wrote:
> exquisitus wrote:
> > hi,
> > at
> > at
> > at
> > at
> > IProjectNature?
> Thanks, Rich Kulp
Thanks, u were rite. i wrote another class which extends
org.eclipse.ui.plugin.AbstractUIPlugin to instantiate the plugin but now
the error message i get is: java.lang.ClassCastException.
if i dont write my own plugin class & let the workbench create a default
plugin then also the same exception occurs on the DefaultPlugin.
what cld be the problem?
Re: project nature [message #29654 is a reply to message #29629] Fri, 09 May 2003 10:12 Go to previous messageGo to next message
In your plugin.xml, in the following section, for which this is an example:
<plugin
id="com.ibm.etools.beaninfo"
name="IBM Beaninfo (Introspection) Support"
version="5.1.0"
class="com.ibm.etools.beaninfo.adapters.BeaninfoPlugin">
Did you remove the class="..."? If you did, then it should be
instantiating default Plugin class (not AbstractUIPlugin, but just plain
Plugin). Please post the ClassCastException trace.
Re: project nature [message #29877 is a reply to message #29654] Tue, 13 May 2003 02:23 Go to previous messageGo to next message
thanx, finally got the plugin working.
is there any way to access the member files/folders of a resource(project)?
> <plugin
> version="5.1.0"
Re: project nature [message #29937 is a reply to message #29877] Tue, 13 May 2003 10:10 Go to previous messageGo to next message
Opps, I was thinking IJavaElement.
For IProject and IFolder, it is members().
Rich
Re: project nature [message #31009 is a reply to message #29937] Wed, 14 May 2003 07:41 Go to previous messageGo to next message
thanx it worked.
now i want to create my own kind of project by implementing the IProject
interface but the eclipse documentation suggests that it is not meant to
be implemented by users. is it possible to implement it or is there any
other way to create my own project class.
> Rich
Re: project nature [message #31344 is a reply to message #31009] Wed, 14 May 2003 10:44 Go to previous messageGo to next message
It is not intended to be done. If you want extended behavior for a
project, you use project natures to provide that behavior, among other
extensions that are also available for projects. Maybe some of those
other extension points can be used to provide what you want.
Rich Kulp
Re: project nature [message #33007 is a reply to message #31344] Thu, 15 May 2003 03:53 Go to previous messageGo to next message
I want to add a nature to any project that is created that is, presently
in my plugin, i'm adding a nature to the project description of a
particular project(project name is hard coded in teh code) but i want to
take this project name at the time the nature is being added from my
wizard. is it possible to obtain the name of the selected project?
> Rich Kulp
Re: project nature [message #33543 is a reply to message #33007] Thu, 15 May 2003 12:49 Go to previous message
If it is a standard new wizard, i.e. defined in:
<extension
point="org.eclipse.ui.newWizards">
Then the init method is sent an IStructuredSelection which
has what was selected (if the active part had a valid selection in it,
as determined by the <selection> element of your extention in your
plugin.xml.
Typically your <selection> should be for
<selection
class="org.eclipse.core.resources.IResource">
</selection>
Then the IStructuredSelection will contain the resources that were
selected. You can ask an IResource for the project that the resource
belongs too.
Remember more than one resource from more than one project may be
selected at the same time, so you need to decide how you handle that
condition.
Then again, nothing compatible may be selected, and you need to handle
that case too.
Rich
Previous Topic:IAdaptable / IResource
Next Topic:Custom projects
Current Time: Mon Nov 10 00:17:47 EST 2025
Powered by FUDForum. Page generated in 0.06341 seconds
