Home » Eclipse Projects » Eclipse Platform » Access restriction: The type ResourcesPlugin is not accessible due to restriction on required librar
Access restriction: The type ResourcesPlugin is not accessible due to restriction on required librar [message #285719] Tue, 24 May 2005 10:16 Go to next message
Originally posted by: mark_melvin.amis.com
Can anyone give me a hint here? I just upgraded to 3.1M7 and my plugins
now have > 100 errors due to classes not being resolved, my MANIFEST.MF
files not declaring "singleton:=true" (in various formats...I have fixed
all of these by searching the newsgroup...) as well as Access
Restrictions like the following:
restriction on required library
C:\path\to\eclipse3.1M7\eclipse\plugins\org.eclipse.core.res ources_3.1.0.jar
I'm assuming the ResourcesPlugin is not actually restricted...at least I
hope it isn't - or that means I have a lot of re-coding to do...
What is triggering these errors? A full clean of my workspace has not
fixed anything.
Mark.
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285728 is a reply to message #285719] Tue, 24 May 2005 11:26 Go to previous messageGo to next message
I ran into similar problems, but with core JRE classes! e.g.,
Access restriction: The type String is not accessible due to restriction
on required library C:\Program Files\IBM\Java142\jre\lib\core.jar
This has to be a bug. Any of the following may be related:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95277
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95853
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95167
....Ron Capelli (Austin)
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285731 is a reply to message #285728] Tue, 24 May 2005 12:18 Go to previous messageGo to next message
Thanks for the bug links. I removed all imported plugins from my
workspace (only had one - pde.ui), restarted my IDE from the command
line with the "-clean" option, and did a full clean, and re-build on my
workspace and the errors are still all there.
<sigh>
I know what I'll be doing this afternoon, I guess...
What also ticks me off is that the Plugin view in the Plugin Development
perspective no longer lets you import single-JAR'd plugins into your
workspace. And you can't simply open plugin.xml like you could before
to see where the funniness lies.
Mark.
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285735 is a reply to message #285731] Tue, 24 May 2005 13:19 Go to previous messageGo to next message
Sorry...I'm a tool. You can still import the plugins. You just can't
view the plugin.xml files directly like you used to be able to.
Mark.
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285742 is a reply to message #285731] Tue, 24 May 2005 17:20 Go to previous messageGo to next message
I found the source of my pain. One of my plug-ins was re-exporting its
dependencies, and this was causing weirdness. Actually, it was
re-exporting them both in the MANIFEST.MF (which appears to work fine),
but also in the Java Build Path > Order and Export project properties
tab (Plug-in Dependencies was checked off as well as its source folder).
Unchecking this caused all of my errors to magically disappear.
I'm thinking this is a bug - so I will enter this into Bugzilla.
Mark.
> <sigh>
> Mark.
>> restriction on required library C:\Program
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285747 is a reply to message #285735] Tue, 24 May 2005 20:31 Go to previous messageGo to next message
Originally posted by: wassimm.ca.ibm.com
Yes you can. Just double click on the plugin.
Wassim.
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285748 is a reply to message #285742] Tue, 24 May 2005 20:34 Go to previous messageGo to next message
Originally posted by: wassimm.ibm.canada
Please NEVER tweak the Plugin Dependencies container in any way in the
Java Build Path properties page, as you would be asking for trouble and
you would be on your own.
Wassim.
> Mark.
>> <sigh>
>> Mark.
>>> restriction on required library C:Program
>>> FilesIBMJava142jrelibcore.jar
You should express your plugin's dependencies through the manifest.mf
exclusively. PDE will take care of the rest.
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285763 is a reply to message #285747] Wed, 25 May 2005 09:16 Go to previous messageGo to next message
> Wassim.
Cool - you *can* get at the plugin.xml of a single-JAR'd plugin by
double-clicking it in the Plug-ins view. You learn something everyday...
Thanks for the heads up. This wasn't obvious - but I guess I should be
a little more adventurous in the future. ;o)
Mark.
Re: Access restriction: The type ResourcesPlugin is not accessible due to restriction on required [message #285764 is a reply to message #285748] Wed, 25 May 2005 09:18 Go to previous message
Good to know. ;o)
I must have checked this off - waaay back when I was first starting with
Eclipse many moons ago. I'm sure I'll never mess with it again. ;O)
Mark.
> Wassim.
>> its dependencies, and this was causing weirdness. Actually, it was
>> fine), but also in the Java Build Path > Order and Export project
>> properties tab (Plug-in Dependencies was checked off as well as its
>> source folder). Unchecking this caused all of my errors to
>> Mark.
>>> my workspace and the errors are still all there.
>>> <sigh>
>>> Mark.
>>>> restriction on required library C:Program FilesIBMJava142jrelibcore.jar
Previous Topic:Perspective and IFolderLayout
Next Topic:addListener to every Editor, not just active Editor
Current Time: Tue Nov 04 01:30:14 EST 2025
Powered by FUDForum. Page generated in 0.06599 seconds
