| Editor for java not opening [message #285620] |
Fri, 20 May 2005 10:14  |
Originally posted by: nospam.nospam.com
Not sure what has happened but I am no longer able to open java files in
Eclipse, nor can I create any java files. I have installed 3.02 and 3.1m5a
in various combinations with java version 1.4.1_05, 1.4.2_08 and 1.4.2_03.
I am really getting tired of all this installing and reinstalling.
I should add that in between each install I have also deleted the workspace
directory. As far as I know I am starting with a completely new install of
everything.
Any ideas what may be causing this problem? Anything else I can try?
-Gary
| Re: Editor for java not opening [message #285633 is a reply to message #285624] |
Fri, 20 May 2005 13:11   |
>> everything.
> Some more details about what happens would be helpful (other than "I
> can't"), but my first suggestion would be that you are installing
> something other than the full Eclipse SDK release. For example, what
> they call the "Platform" release does not include the JDT (Java tools),
> so it will be frustrating if you're trying to do Java development with
> it ;-)
> What is the name of the ZIP file you downloaded and are installing from?
> HTH,
> Eric
I am pretty sure I am installing the full sdk release. The files are :
eclipse-SDK-3.0.2-win32.zip
eclipse-SDK-3.1M5a-win32.zip
eclipse-SDK-3.1M7-win32.zip
This AM (after running a defrag last night) I used regcleaner and jv power
tools 16 to clean up my registry. For no apparent reason Eclipse started
to work after these two tasks. Must have been something wonky in the
registry. FWIW, I never did see any (Eclipse) log messages either that
would indicate a problem. This is what one gets when using XP for dev....
-Gary
| Re: Editor for java not opening [message #285692 is a reply to message #285633] |
Mon, 23 May 2005 11:18   |
>>>everything.
>>it ;-)
>>HTH,
>> Eric
Yep, those are the correct files for getting "full" Eclipse including JDT.
Just for your own sanity, Eclipse does not use the windoze registry at
all, so it is not likely that any registry work directly led to the
problem going away. It is possible that some general JRE/JDK registry
cleanup happened - if you launch Eclipse without specifying a particular
JRE/JDK location (you should be using -vm option, highly recommended),
then such registry changes could affect Eclipse indirectly by changing
the system's Java settings.
Eric
| Re: Editor for java not opening [message #286118 is a reply to message #285692] |
Thu, 02 June 2005 14:26  |
Originally posted by: NOSPAM_astonchan.yahoo.com
It may not be your problem but I remember it appeared to happen to me
once. It turned out, I had the .java extension mistakenly set to some
other editor which won't show up for java file.
FUDForum. Page generated in 0.04205 seconds
