Home » Eclipse Projects » Eclipse Platform » OSGI install and start plugin in runtime HELP
OSGI install and start plugin in runtime HELP [message #284599] Wed, 27 April 2005 12:32 Go to next message
Hi all,
it is possible to install and start external plugins with remote OSGi
console. (install and start commands)
I need the same funktionality, but in the runtime. There is an interface
BundleContext for that, could you please give me a piece of advice how
do I get the instance of that in my workbench environment?
Thanks a lot,
Ilya
Re: OSGI install and start plugin in runtime HELP [message #284624 is a reply to message #284599] Wed, 27 April 2005 17:25 Go to previous messageGo to next message
Originally posted by: schulz78.gmx.net
Hi Ilya,
I think you can access a BundleContext instance within the lifecycle
methods (start/stop) of a bundle activator (defined in the Manifest.mf,
may be an extension of the Plugin class). But be careful! If I remember
right, this instance is only valid within these methods.
Hope this helps.
Sven Schulz
Ilya Shinkarenko wrote:
> Hi all,
> Thanks a lot,
> Ilya
Re: OSGI install and start plugin in runtime HELP [message #284659 is a reply to message #284624] Thu, 28 April 2005 06:55 Go to previous messageGo to next message
Hi Sven,
thank you for the hint.
Nevertheless, I still have the following problem: when I try to install
the plugin (doesn't matter how - with console or programmaticaly) I got
the following error (please see the stacktrace below, it's rather long).
The directory
D:\dev\eclipse3\workspace\.metadata\.plugins\org.eclipse.pde .core\OSGI
loader\org.eclipse.osgi\bundles\ is empty, there are no subdurs neither
files in it.
Any ideas?
org.osgi.framework.BundleException: Error converting plugin at
loader\org.eclipse.osgi\bundles\12\1\admin-editor.zip.
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:236)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:191)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:280)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:472)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$1.run(Fra mework.java:635)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:630)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:198)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._install(FrameworkCommandProvider.java:280)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:139)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:292)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:277)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:236)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:207)
at java.lang.Thread.run(Thread.java:534)
Caused by:
org.eclipse.osgi.service.pluginconversion.PluginConversionEx ception:
Could not find a plugin.xml or a fragment.xml in
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:110)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:660)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:233)
... 22 more
Nested Exception:
Nested Exception:
Sven Schulz wrote:
> Hi Ilya,
> Hope this helps.
> Sven Schulz
>> Hi all,
>> interface BundleContext for that, could you please give me a piece of
>> advice how do I get the instance of that in my workbench environment?
>> Thanks a lot,
>> Ilya
Re: OSGI install and start plugin in runtime HELP [message #284720 is a reply to message #284659] Fri, 29 April 2005 05:25 Go to previous message
The problem is solved - the solution is to export plugins, which are to
be istalled, as a "Individual jar archive for update site". Why does it
not function with zip or directory structure exported plugins - not
clear, seems like an eclipse bug :-(
> Hi Sven,
> The directory
> files in it.
> Any ideas?
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> ... 22 more
> Nested Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Nested Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Sven Schulz wrote:
>> Hi Ilya,
>> Manifest.mf, may be an extension of the Plugin class). But be careful!
>> If I remember right, this instance is only valid within these methods.
>> Hope this helps.
>> Regards,
>> Sven Schulz
>>> Hi all,
>>> Thanks a lot,
>>> Ilya
Previous Topic:Eclipse Help Problem
Next Topic:Syntax highligting - PLEASE HELP
Current Time: Thu Sep 25 18:31:12 EDT 2025
Powered by FUDForum. Page generated in 0.03457 seconds
