Home » Eclipse Projects » Babel » Getting Galileo langpacks to work without p2 metadata
| Getting Galileo langpacks to work without p2 metadata [message #28397] |
Tue, 19 May 2009 00:45  |
Owing to [https://bugs.eclipse.org/274025], p2 metadata isn't being
generated for Babel, and hasn't been for a month or so.
Has anyone been able to install langpacks in Galileo since the p2
metadata stopped? I can only get them to install if I generate p2
metadata myself (by using my patch to fix the above bug). Otherwise,
the p2 update manager UI says "There are no items available."
If it's just me having this problem, would someone mind sharing the trick?
If it's not just me, I think [https://bugs.eclipse.org/276306], and
perhaps 274025, deserve higher severity than "normal". Quite a bit higher.
Sean.
| Re: Getting Galileo langpacks to work without p2 metadata [message #28463 is a reply to message #28397] |
Tue, 19 May 2009 03:40   |
On 05/19/2009 02:45 PM, Sean Flanigan wrote:
> Regards
> Sean.
Further to my own post, I have discovered that Galileo will pick up the
zipped langpacks (without metadata) if you unzip the plugins into, say,
eclipse/dropins/babel/plugins, and simply throw away the features.
(Note that Eclipse starts pretty slowly the first time, because it has
to scan the dropins directory. So don't try doing it for too many
languages.)
I think this works because it lets Eclipse ignore the incomplete
dependencies of the features (they depend on plugin fragments which are
there, but not all the host plugins are installed). Since dropins only
contains fragments, p2 just tries to use as many fragments as possible,
and ignores the rest.
However, I still haven't been able to get Galileo langpacks working via
the update site. Any advice appreciated!
Sean.
| Re: Getting Galileo langpacks to work without p2 metadata [message #28976 is a reply to message #28463] |
Thu, 28 May 2009 10:13  |
Eclipse Webmaster Messages: 607353 Registered: July 2009 |
>> trick?
>> higher.
>> Regards
>> Sean.
> eclipse/dropins/babel/plugins, and simply throw away the features. (Note
> that Eclipse starts pretty slowly the first time, because it has to scan
> the dropins directory. So don't try doing it for too many languages.)
> Sean.
Hi Sean,
Thanks so much for your insight and all your involvement. I've just
posted a message to babel-dev regarding all this. Since your patch is
unlikely to make it into Eclipse 3.5, we will need to consider other
options for the update site.
Perhaps the easiest way out would be for me to run a patched p2 to
generate the metadata. I will look into this.
Denis
| Re: Getting Galileo langpacks to work without p2 metadata [message #578816 is a reply to message #28397] |
> Regards
> Sean.
languages.)
Sean.
| Re: Getting Galileo langpacks to work without p2 metadata [message #578853 is a reply to message #28463] |
>> trick?
>> higher.
>> Regards
>> Sean.
> Sean.
Hi Sean,
Denis
Current Time: Fri Nov 07 11:14:49 EST 2025
Powered by FUDForum. Page generated in 0.04189 seconds
