Rendering IVariable in red [message #284338] |
Thu, 21 April 2005 09:10  |
Originally posted by: Daniel.Hirscher.innovations.de
I'm writing an own debugger. Everything is fine, except the variables
view rendering changed values in red, which does not work for me.
I'm caching my IValue values in IVariable as JDI does.
I'm caching my IVariables (sub variables) in my Value object, as JDI does.
The variable view contains a variable which itself contains some other
variables, like this:
-+ parameters
+- parameter 1
+- parameter 2
When I step through my suspend counter increments.
But the variables view collapses the "parameters" container variable.
I expect this not to be happen!
Why and where are my Variables are thrown away.
Do I have to cache the stackframes?
Do I have to transfer some sort of state between my debugTarget and the
program under debug?
What is the last secret to get it working?
I read the slides from the eclipse con 2005 debug tutorial which I found
is very good, but the red flag is not included in the examples.
BTW: when to expect the book to be available?
Daniel
Re: Rendering IVariable in red [message #284379 is a reply to message #284338] |
Fri, 22 April 2005 05:18  |
hi daniel,
the key method is boolean IVariable.hasValueChanged()
it is used by VariablesViewDecoratingLabelProvider (part of the eclipse
debug ui plugin) which paints each variable.
the getForeground snippet of VariablesViewDecoratingLabelProvider:
public Color getForeground(Object element)
if (element instanceof IVariable)
IVariable variable = (IVariable) element;
try
if (variable.hasValueChanged())
return
DebugUIPlugin.getPreferenceColor(IDebugPreferenceConstants.C HANGED_VARIABLE_COLOR);
catch (DebugException e)
DebugUIPlugin.log(e);
return super.getForeground(element);
in my debugger after suspension of the debugged process i compare the
new stackframes with the old ones and check everything which was before
there and changed. in other words your ivariable impl has to take care
that method hasValueChanged() returns the right thing.
hope this helps.
regards,
lars gersmann
Daniel Hirscher wrote:
> -+ parameters
> +- parameter 1
> +- parameter 2
> Daniel
FUDForum. Page generated in 0.03272 seconds
