Re: Proxying Maven central [message #1550782 is a reply to message #1548898] |
Wed, 07 January 2015 08:05 |
On 2015-01-06 08:47, David Williams wrote:
> On 01/05/2015 04:18 AM, Thomas Elskens wrote:
>> It answers my question indeed : the documentation of b3 aggregator left me puzzled about this ("p2 and maven2 support
>> -- the aggregator can aggregate from and to both p2 and maven2 repositories").
>> Thanks for the clarification,
>> Thomas
> It can create a maven repository ... but, as far as I know, can not pull from one ... at least, not in the general case.
That's correct in practice. In theory, there is actually a 'maven2' nature that can be set for a mapped repository. When
set, b3 will make an attempt to pull from a repository with maven2 layout. If the "Nexus Indexer for Maven" feature is
installed, and if the repository in question is indexed, it might succeed in doing so but without it, you're probably
out of luck.
In any case, the 'pull from maven' functionality needs more work and I wouldn't recommend building a solution on it as
it stands today (unless you're also willing to contribute to b3 to improve that situation of course).
- thomas
FUDForum. Page generated in 0.03891 seconds
