Home » Eclipse Projects » Eclipse Platform » How to Run an Eclipse Plugin App as a pure Java App
How to Run an Eclipse Plugin App as a pure Java App [message #283078] Fri, 25 March 2005 12:38 Go to next message
I'd like to profile our Eclipse plugin based application with OptimizeIt.
However, this requires me to run it as a normal Java Application. I know
I can run Eclipse itself with:
java -Xms512m -Xmx768m -cp startup.jar org.eclipse.core.launcher.Main -debug
-consoleLog
I also can run it from in the IDE with:
-dev bin -install file:<eclipse_dir> -data <workspace_dir>
However, I want it to run with the plugins in my workspace directory instead
of the plugins in my install directory.
Re: How to Run an Eclipse Plugin App as a pure Java App [message #283116 is a reply to message #283078] Fri, 25 March 2005 18:55 Go to previous message
> org.eclipse.core.launcher.Main -debug -consoleLog
> instead of the plugins in my install directory.
Doesn't OptimizeIt provide an IDE integration? Just use the Eclipse
integration.
If you do not brought an Eclipse enabled version, install Eclipse in a
special
directory and export your plugins into the workspace. So you can profile
this
directory.
Another idea is trying to use the -data workspace-dir argument within the
your setup line:
I don't know but I guess the data parameter is also working for the
launcher.Main class.
Martin (Kersten)
Previous Topic:Updating the Help index when debugging
Next Topic:ISearchResultPage and org.eclipse.search.searchResultViewPages framework non-usable
Current Time: Sat Jul 05 03:04:48 EDT 2025
Powered by FUDForum. Page generated in 0.03338 seconds
