java.lang.ClassFormatError: (Illegal UTF8 string in constant pool) [message #282975] |
Thu, 24 March 2005 10:26 |
Originally posted by: denis.roudet.rd.francetelecom.com
Hi everyone,
I am developing a plug-in in Eclipse which made automatic tests on Java
classes. So I have to load dynamically these classes. Then I write a
specific ClassLoader and it works with simple classes. But when I want to
load a class from a jar file I have got this error :
java.lang.ClassFormatError: core/ChetEnvir (Illegal UTF8 string in
constant pool)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:502)
at java.lang.ClassLoader.defineClass(ClassLoader.java:431)
fr.francetelecom.rd.chetBaker.actions.ChetBakerClassLoader.f indClass(ChetBakerClassLoader.java:147)
at java.lang.ClassLoader.loadClass(ClassLoader.java:299)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:15 90)
at java.lang.Class.getConstructors(Class.java:848)
This a copy of my class in which I make my ClassLoader
public class ChetBakerClassLoader extends ClassLoader
private IJavaProject project;
private IPath rootLocation;
private Set/*[IClasspathEntry]*/ entries = new HashSet();;
private static int BUFSIZE = 2048;
/**Makes a new classloader in order to load classes in a specified
project.
* @param _cl The parent ClassLoader.
* @param _prj The specified project.
* @throws IllegalArgumentException
public ChetBakerClassLoader(ClassLoader _cl, IJavaProject _prj)
super(_cl);
if (_prj == null)
new IllegalArgumentException("invalid null project ");
if (!_prj.exists() || !_prj.isOpen())
new IllegalArgumentException("invalid project " + _prj);
project = _prj;
rootLocation = ResourcesPlugin.getWorkspace().getRoot().getLocation();
project.
public ChetBakerClassLoader(IJavaProject _prj) throws
this(null, _prj);
/**Stores the .classpath of the project in a set.
* @throws JavaModelException
public void initPath() throws JavaModelException
IClasspathEntry[] ents = project.getResolvedClasspath(true);
for (int i = 0; i < ents.length; i++)
entries.add(ents[i]);
/* (non-Javadoc)
* @see java.lang.ClassLoader#findClass(java.lang.String)
protected Class findClass(String _nm)
byte[] buf = null;
try {
buf = readBytes(_nm);
catch (Exception e) {
e.printStackTrace();
throw new Error("pb wheb reading bytes[]");
if (buf == null)
throw new Error("Empty buffer ");
return defineClass(_nm, buf, 0, buf.length);
private byte[] readBytes(String _nm) throws Exception
if (entries == null)
throw new Error("No path to load the class");
byte[] resultat = null;
Path relP2CFile = new Path(_nm.replace('.', '/') + ".class");
System.out.println("String pour jar : "+ relP2CFile.toString());
for (int i = 0; i < entries.size(); i++) {
IClasspathEntry entriesElement = (IClasspathEntry)
entries.toArray()[i];
if (entriesElement.getEntryKind() == IClasspathEntry.CPE_SOURCE)
IPath pth = entriesElement.getOutputLocation();
if (pth == null)
pth = project.getOutputLocation();
if (pth != null)
pth = rootLocation.append(pth);
else
pth = rootLocation;
if (pth.append(relP2CFile).toFile().exists())
return getBytesFromFile(pth.append(relP2CFile).toFile());
else
if (entriesElement.getEntryKind() == IClasspathEntry.CPE_PROJECT)
else
if (entriesElement.getEntryKind() == IClasspathEntry.CPE_LIBRARY)
if (entriesElement.getContentKind() ==
IPackageFragmentRoot.K_BINARY)
IPath jarPath = entriesElement.getPath();
try
//Cas ou le .jar est un fichier externe au projet
if (jarPath.toFile().exists())
return getBytesFromJar(jarPath.toFile(),
else
IPath jarPathInternal = rootLocation.append(jarPath);
if (jarPathInternal.toFile().exists())
return getBytesFromJar(jarPathInternal.toFile(),
catch (ClassNotInThisJarException e)
//do nothing
throw new Error("Problem with the spot of the class");
private static byte[] getBytesFromFile(File _fil)
if (_fil == null || !_fil.exists())
throw new Error("Empty file or does not exist");
InputStream stm = null;
try {
stm = new BufferedInputStream(new FileInputStream(_fil));
byte[] buf = new byte[BUFSIZE];
int sz = 0;
while (true) {
int cnt = stm.read(buf, sz, buf.length - sz);
if (cnt < 0)
throw new Error ("Problème when reading file");
sz += cnt;
if (sz < buf.length)
break;
byte[] newBuf = new byte[buf.length + BUFSIZE];
System.arraycopy(buf, 0, newBuf, 0, sz);
buf = newBuf;
byte[] res = new byte[sz];
System.arraycopy(buf, 0, res, 0, sz);
return res;
catch (Exception ex) {
throw new Error("Problem with the transformation File->Bytes");
finally {
try {
if (stm != null) {
stm.close();
catch (IOException ex) {
throw new Error("Problem with closing InputStream");
// I THINK THIS
private static byte[] getBytesFromJar(File _jar, String _fil) throws
Exception
if (_jar == null || !_jar.exists())
throw new Error("Ce jar n'existe pas");
if (_fil == null)
throw new Error("La classe recherchée est vide");
// String fName = _fil.getName();
ZipFile zip = null;
byte[] res = null;
try {
zip = new ZipFile(_jar);
ZipEntry ent = zip.getEntry(_fil);
if (ent == null)
throw new ClassNotInThisJarException();
stm = zip.getInputStream(ent);
int sz = (int) ent.getSize();
res = new byte[sz];
int nbBytesRead = stm.read(res, 0, sz);
System.out.println("Taille de la classe dans le .jar : " + sz);
System.out.println("Nombres de bytes lues : " + nbBytesRead);
for (int i = 0; i < res.length; i++) {
System.out.println(res[i]);
finally {
if (stm != null)
stm.close();
if (zip != null)
zip.close();
return res;
Re: java.lang.ClassFormatError: (Illegal UTF8 string in constant pool) [message #282979 is a reply to message #282975] |
Thu, 24 March 2005 09:15  |
Originally posted by: olivier_thomannNOSPAM.ca.ibm.com
Denis a écrit :
> Hi everyone,
> to load a class from a jar file I have got this error :
> constant pool)
> at
Does it work using the default classloader?
If not, then could you please open a bug report against JDT/Core with
the file ChetEnvir.class in the folder core as an attachment.
Olivier
FUDForum. Page generated in 1.05194 seconds
