c:iterate and inheritance in a model [message #28183] |
Tue, 24 July 2007 06:07  |
I'm wondering if it's possible to loop through two different classes in a
EMF model if one inherits the other. Let's say I have the two following
classes in my diagram:
Apple(name, color) <---- SpecialApple (specialAttribute)
SpecialApple inherits the name and color from the Apple class.
Now if I want to iterate through all the apples to print their names for
example in a JET2 transformation I can do two loops. One goes through all my
Apples, the other through the SpecialApples.
<c:iterate select="$currTree/apples" var="currApple">
</c:iterate>
<c:iterate select="$currTree/specialApples" var="currApple">
</c:iterate>
We can see here that the two loops are nearly the same so I was wondering
weather it's possible to merge them into only one loop just for a matter of
clarity of the code
Thanks, Tex.
Re: c:iterate and inheritance in a model [message #28373 is a reply to message #28183] |
Wed, 25 July 2007 08:55   |
Tex:
From you examples, it appears that SpecialApple and Apple are in different
collections/features of $currTree. If they are then you could try the
following:
<c:iterate select="$currTree/apples | $currTree/specialApples"
var="currApple">
</c:iterate>
But, if Apple and SpecialApple instances are added to the same feature, say
allApples, you merely have to write:
<c:iterate select="$currTree/allApples" var="currApple">
<%-- To distinguish SpecialApple for Apple --%>
<c:if test="$currApple[self::SpecialApple]">
.... stuff only for SpecialApple. similarly, self::Apple identifies only
Apple instances (not SpecialApple)
</c:if>
</c:iterate>
Paul
"Tex Twil" <chaljan@hotmail.com> wrote in message
news:f84j0v$it6$1@build.eclipse.org...
> my Apples, the other through the SpecialApples.
> </c:iterate>
> </c:iterate>
> of clarity of the code
> Thanks, Tex.
Re: c:iterate and inheritance in a model [message #28996 is a reply to message #28373] |
Thu, 26 July 2007 03:55  |
Hello Paul,
the first possibility works, thank you.
regards,
Tex
"Paul Elder" <pelder@ca.ibm.com> a écrit dans le message de
news:f87h8l$ucv$1@build.eclipse.org...
> Tex:
> following:
> var="currApple">
> </c:iterate>
> say allApples, you merely have to write:
> </c:if>
> </c:iterate>
> Paul
>> </c:iterate>
>> </c:iterate>
>> Thanks, Tex.
FUDForum. Page generated in 0.03790 seconds
