Home » Eclipse Projects » Eclipse Platform » erratic response to Text.setFocus
erratic response to Text.setFocus [message #282693] Thu, 17 March 2005 15:12 Go to next message
Originally posted by: cervezas.no-spam-pikesoft.com
I have a Master-Details style FormEditor that opens different kind of
DetailsPages depending on which object is selected in the Table of my
MasterPart. (These details may not be relevant, but I provide them just in
case.) My problem is that when I change the selection and update the
DetailsPage I want to have the focus go to the first widget on the form,
which in each case happens to be a Text widget. Simple enough: I add a call
to myText.setfocus to the update() method of each of my DetailsPages and
make sure it gets called when selectionChanged() is called. And this
works... sometimes.
I've verified that setfocus() is being called every time I want it to, but
it only actually sets the focus in that widget about half the time. I
haven't been able to detect a pattern for when it succeeds and fails, but it
seems like it always succeeds the first time it is called on a particular
Text widget and starts to get flaky only on subsequent calls.
Very strange, and problematic since this application is designed to allow
quick data entry. Any clues to what might be happening?
David
Re: erratic response to Text.setFocus [message #282731 is a reply to message #282693] Fri, 18 March 2005 09:06 Go to previous messageGo to next message
Hi David,
1. Which platform(s) do you see or not see this problem on?
2. In the cases where focus does not get into the Text, where does focus end
up? Is it left on the previous focus widget, or does it seemingly
disappear, or go somewhere random?
3. Does async'ing your setFocus() call help? ie.-
text.getDisplay().asyncExec(new Runnable() {
public void run() {
text.setFocus();
Grant
"David Beers" <cervezas@no-spam-pikesoft.com> wrote in message
news:d1cocd$opo$1@www.eclipse.org...
in
call
> works... sometimes.
it
> David
Re: erratic response to Text.setFocus [message #282934 is a reply to message #282731] Wed, 23 March 2005 20:41 Go to previous message
Yep, asynching fixed the problem.
Thanks, Grant!
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:d1en8f$5hb$1@www.eclipse.org...
> Hi David,
end
> public void run() {
> text.setFocus();
> Grant
> in
> call
> > works... sometimes.
but
but
> it
particular
allow
> > David
Previous Topic:ActiveX Control License File
Next Topic:Manifest file editing for library plug-ins
Current Time: Sat Sep 13 15:07:01 EDT 2025
Powered by FUDForum. Page generated in 0.18747 seconds
