| Intercepting [message #282537] |
Tue, 15 March 2005 20:31  |
Originally posted by: sabell.txesystems.com
I'm using EMF to generate a model and the associated simple UI.
When I use the right-click menu to create a new child of an item in a tree,
I need to intercept that object before it is added to its parent and make
some modifications.
Where can one get ahold of this child just before it is added?
Steve
| Re: Intercepting [message #282571 is a reply to message #282551] |
Wed, 16 March 2005 11:53   |
------=_NextPart_000_004E_01C52A05.970FB800
Content-Type: text/plain;
charset="iso-8859-1"
Unfortunately, that won't work here.
I need to get the single object that is actually selected.
Modifying all objects that are created in collectNewChildDescriptors()
will create an unrecoverable mess in this situation.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:d19b26$6bv$1@www.eclipse.org...
Steve,
You can modify the generated method:
protected void collectNewChildDescriptors(Collection =
newChildDescriptors, Object object)
to initialize the new instance however you like.
Steven T Abell wrote:=20
When I use the right-click menu to create a new child of an item in a =
tree,
I need to intercept that object before it is added to its parent and =
make=20
some modifications.
Steve
=20
Content-Type: text/html;
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2604" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Unfortunately, that won't work =
here.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I need to get the single object that is =
actually=20
selected.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Modifying all objects that are created =
in=20
collectNewChildDescriptors()</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>will create an unrecoverable mess in =
this=20
situation.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:d19b26$6bv$1@www.eclipse.org">news:d19b26$6bv$1@www.eclipse.=
org</A>...</DIV>Steve,<BR><BR>You=20
can modify the generated method:<BR>
<BLOCKQUOTE>protected void collectNewChildDescriptors(Collection=20
newChildDescriptors, Object object)<BR></BLOCKQUOTE>to initialize =
the new=20
instance however you like.<BR><BR><BR>Steven T Abell wrote:=20
<BLOCKQUOTE cite=3Dmidd1826g$7pl$1@www.eclipse.org type=3D"cite"><PRE =
wrap=3D"">I'm using EMF to generate a model and the associated simple =
UI.
tree,
make=20
some modifications.
Steve
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_004E_01C52A05.970FB800--
| Re: Intercepting [message #282608 is a reply to message #282571] |
Wed, 16 March 2005 16:04  |
--------------080307060006080006090505
Steve,
Your comment seems to imply that the initialization of the new child
will depend on where you add it. Is that true? If so, Marcos comment
about overriding the create child command behavior is the way to go...
(This question is asked in so many newsgroups, where EMF seems the only
place you should ask this.)
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:d19b26$6bv$1@www.eclipse.org...
> Steve,
>>some modifications.
>>Thanks,
>>Steve
<html>
<head>
</head>
Steve,<br>
<br>
place you should ask this.)<br>
<br>
<br>
<blockquote cite="midd19o5v$jka$1@www.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.2604" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Unfortunately, that won't work here.</font></div>
<div><font face="Arial" size="2">I need to get the single object that
is actually selected.</font></div>
<div><font face="Arial" size="2">Modifying all objects that are
created in collectNewChildDescriptors()</font></div>
<div><font face="Arial" size="2">will create an unrecoverable mess in
this situation.</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
wrote in message <a href="news:d19b26$6bv$1@www.eclipse.org">news:d19b26$6bv$1@www.eclipse.org</a>...</div>
Steve,<br>
<br>
You can modify the generated method:<br>
<blockquote>protected void collectNewChildDescriptors(Collection
newChildDescriptors, Object object)<br>
</blockquote>
to initialize the new instance however you like.<br>
<br>
<br>
<blockquote cite="midd1826g$7pl$1@www.eclipse.org" type="cite">
<pre wrap="">I'm using EMF to generate a model and the associated simple UI.
some modifications.
Steve
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080307060006080006090505--
FUDForum. Page generated in 0.04512 seconds
