Re: New component types not registering in headless product [message #28178 is a reply to message #28139] |
Fri, 14 November 2008 01:08 |
Hi Jim,
Are you sure the plugin.xml is included in the bundle jar? Is your bundle declared with
singleton=true?
Can you provide your plugin.xml for the bundle in question?
Thomas Hallgren
Jim Strawn wrote:
> Hello,
> I have created a feature to allow the Tigerstripe product to be used
> with Buckminster. In doing so, I've implemented two new component types.
> The new component types will work for me when I am using them from a
> standard Eclipse workbench, but when trying to use them from a headless
> environment Buckminster does not seem to resolve my extentions. I
> believe that I have all of the required plugin/feature installed in my
> tigerstripe buckminster headless product. Output below.
> I was wondering if anyone could pass along any pointers on debugging this.
> Thanks much,
> Jim Strawn
> $./buckminster --loglevel debug -data ../workspace resolve
> http://www.eclipse.org/tigerstripe/queries/eclipse-summit-08 .cquery
> resolve
> ' http://www.eclipse.org/tigerstripe/queries/eclipse-summit-08 .cquery'
> Downloading
> Platform install location:
> /Users/jimstrawn/Development/headless/buckminster
> Target platform provided by class
> org.eclipse.buckminster.core.TargetPlatform
> Equipment-model:tigerstripe: Using resolver rmap
> ERROR [0001] : No component type with id tigerstripe has been
> registered with extension-point org.eclipse.buckminster.core.componentTypes
> Doing full workspace refresh
> ERROR: Error while refreshing workspace: null
> Waiting for jobs to end
> Command canceled
Re: New component types not registering in headless product [message #28294 is a reply to message #28178] |
Fri, 14 November 2008 14:54 |
Jim Strawn Messages: 29 Registered: July 2009 |
--------------090804050805050506080900
Hi Thomas,
Thanks for prompt response!
I have attached plugin.xml. I do have the bundle declared with
singleton=true. I also unzipped the .jar and verified that plugin.xml
was included. I'm obviously missing something, though.
Jim
Thomas Hallgren wrote:
> Hi Jim,
> bundle declared with singleton=true?
> Regards,
> Thomas Hallgren
> Jim Strawn wrote:
>> Hello,
>> types. The new component types will work for me when I am using them
>> from a standard Eclipse workbench, but when trying to use them from a
>> headless environment Buckminster does not seem to resolve my
>> extentions. I believe that I have all of the required plugin/feature
>> installed in my tigerstripe buckminster headless product. Output below.
>> this.
>> Thanks much,
>> Jim Strawn
>> resolve
>> Downloading
>> Command canceled
Content-Type: text/xml;
name="plugin.xml"
Content-Disposition: inline;
filename="plugin.xml"
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.buckminster.core.componentTypes">
<componentType
class=" org.eclipse.tigerstripe.workbench.optional.buckminster.inter nal.TigerstripeProjectComponentType "
id="tigerstripe">
</componentType>
<componentType
class=" org.eclipse.tigerstripe.workbench.optional.buckminster.inter nal.TigerstripeGeneratorComponentType "
id="tigerstripe.generator">
</componentType>
</extension>
<extension
point="org.eclipse.buckminster.core.actors">
<actor
ID="tigerstripe.installGenerator"
class=" org.eclipse.tigerstripe.workbench.optional.buckminster.inter nal.actor.InstallGeneratorActor "
name="tigerstripe.installGenerator">
</actor>
</extension>
</plugin>
--------------090804050805050506080900--
FUDForum. Page generated in 0.03289 seconds
