| CTableTree, CTree????? [message #27990] |
Thu, 08 February 2007 17:37  |
Originally posted by: alnospammajor.noboxspamspoon.com
what's going on with CTableTree? i just tried running my CTableTree
based code after a couple of months, and am getting lots of compilation
errors. among other things it looks like CTableTree has been renamed
CTree, but this doesn't actually compile.
before i investigate any further, i wanted to make sure that i'm not
missing anything obvious (like the code having moved to a different
repository). is there currently a working version of this widget?
al
| Re: CTableTree, CTree????? [message #28184 is a reply to message #28068] |
Thu, 08 February 2007 18:31  |
i've started refactoring my own code to reflect the changes. most of it
is pretty self-explanatory from looking at the snippets.
i have a viewer class derived from the CTreeViewer (to override
doUpdateItem). it's calling doUpdateCell which appears to have
disappeared from the base class. is there a preferred replacement method?
btw, jeremy you may want to delete the
org.eclipse.swt.widgets.ctabletree package from the repository. that way
it'll be clear from compilation errors that all those classes have been
replaced by differently named ones.
regards,
al
Jeremy Dowdall wrote:
> Yes, CTableTree is being renamed and refactored as CTree:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=162138
> The first working version is targeted for the end of February for gtk
> and win32.
>> compilation errors. among other things it looks like CTableTree has
>> been renamed CTree, but this doesn't actually compile.
>> al
| Re: CTableTree, CTree????? [message #578000 is a reply to message #27990] |
Thu, 08 February 2007 17:56  |
and win32.
> al
| Re: CTableTree, CTree????? [message #578008 is a reply to message #28030] |
Thu, 08 February 2007 18:01  |
The CTreeViewer was rebuilt using a patched version of 3.3M4 to test all
of Tom's hard work. When 3.3M5 is out this viewer will be updated
accordingly and then things like TreePaths should work correctly :)
Al Major wrote:
> correction. it's the CTreeViewer that doesn't compile, not CTree.
> al
| Re: CTableTree, CTree????? [message #578042 is a reply to message #28107] |
Thu, 08 February 2007 18:24  |
ahh. good. 3.3M5 is scheduled for tomorrow, so i should be able to test
it soon.
>> al
| Re: CTableTree, CTree????? [message #578081 is a reply to message #28068] |
regards,
al
> and win32.
>> al
FUDForum. Page generated in 0.05893 seconds
