Home » Eclipse Projects » Eclipse Platform » Access configuration files in plugin root
Access configuration files in plugin root [message #280029] Thu, 27 January 2005 07:56 Go to next message
Originally posted by: dorus.savatech.ro
Hello everybody,
I want to access programatically some configuration files which are
situated in the plugin root (on the same level with plugin.xml). I don't
want that the config files to be located inside the plugin jar.
Do you have any idea?
Thank you very much,
Doru
Re: Access configuration files in plugin root [message #280034 is a reply to message #280029] Thu, 27 January 2005 08:19 Go to previous message
Doru Sular wrote:
> Hello everybody,
> Doru
I found the solution (on eclipse faq site)
Bundle bundle = Platform.getBundle("pluginid");
Path path = new Path("myfile");
URL fileURL = Platform.find(bundle, path);
InputStream in = fileURL.openStream();
regards,
Doru
Previous Topic:org.eclipse.perfmsr.core_0.0.0 Error
Next Topic:ERROR - org.eclipse.team.core.TeamException
Current Time: Sun Nov 09 11:22:18 EST 2025
Powered by FUDForum. Page generated in 0.03421 seconds
