Home » Archived » Test and Performance Tools Platform (TPTP) » Execution flow
Execution flow [message #27835] Tue, 23 August 2005 14:45 Go to next message
Originally posted by: pergentinoaraujo.bol.com.br
When i choose my monitor to open with "execution flow", show the text:
No data is available for display.
The object selected in the Profiling Monitor view does not contain this
type of information.
Note:
Populate the view by selecting a valid item in the Profiling Monitor
view, or start monitoring a Java process.
Use Profile action from Profiling perspective to launch or attach to a
java process.
How i show the diagram ???
[]'s Pergentino.
Re: Execution flow [message #28033 is a reply to message #27835] Wed, 24 August 2005 12:17 Go to previous message
You need to run your profiling session using the Execution History - Full
Graphical Detail profiling set. When you launch your application or attach
to your application look in the Launch configuration dialog, select the
Profiling tab and then the Overview tab, you'll notice 4 predefined
profiling sets one of wich is Execution History - Full Graphical Detail.
"Jose Pergentino" <pergentinoaraujo@bol.com.br> wrote in message
news:defqrv$1em$1@news.eclipse.org...
> Note:
> java process.
> []'s Pergentino.
Previous Topic:Can I create a symptom database file programatically?
Next Topic:TPTP and Tomcat Plugin
Current Time: Mon Oct 27 23:47:01 EDT 2025
Powered by FUDForum. Page generated in 0.04901 seconds
