Home » Eclipse Projects » Eclipse Platform » onLoad( ) and onSave( ) ??
onLoad( ) and onSave( ) ?? [message #279343] Sun, 16 January 2005 14:03 Go to next message
Hi all,
Is there a way that I can retrieve the data (e.g. getDocument ) of a
TextEditor plugin when its first loaded and again BEFORE its saved?
I need to do some work whereby I filter/strip out some data when the
document is loaded and then put it back in again when its saved. I dont want
the data to be there while the user is actually editing the source code
file.
I've found the TextEditor::editorSaved( ) method, but this is raised AFTER
eclipse has committed the file to disk.
Any hints as to where I should be looking? Surely I can't be the only one
who wants to do this sort of thing?
Jack
Re: onLoad( ) and onSave( ) ?? [message #279354 is a reply to message #279343] Mon, 17 January 2005 05:06 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Jack Hoxley wrote:
>Hi all,
>file.
I see two choices here:
1) write your own IDocumentProvider
2) write your own ITextFileBuffer (this has the advantage that it can be
used without having an editor
Dani
>Cheers,
>Jack
Re: onLoad( ) and onSave( ) ?? [message #279359 is a reply to message #279354] Mon, 17 January 2005 07:28 Go to previous messageGo to next message
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:csg2mi$3i0$1@www.eclipse.org...
> Dani
Thanks for the information, appreciated.
I'm not quite seeing how those two (once customized) fit into the rest of
the editor?
I presume that, at some point, I need to replace whatever default
IDocumentProvider or ITextFileBuffer is being used with my own
implementation. Unfortunately I can't see where this would be.
My editor is mostly based on the "javaeditor" example bundled with eclipse.
My document partitioning is therefore handled via the
"org.eclipse.core.filebuffers.documentSetup" extension point, do I need to
change this and/or add a new extension point and point it to my
implementation?
Any further tips would be greatly appreciated :-)
Jack
Re: onLoad( ) and onSave( ) ?? [message #279377 is a reply to message #279359] Mon, 17 January 2005 11:42 Go to previous messageGo to next message
>>Dani
>the editor?
>implementation?
I need some more info first:
- what kind of files do you want to open in your editor?
- would other clients except the editor also want to work with the
stripped file?
- do you also use org.eclipse.core.filebuffers.documentCreation?
Dani
>Cheers,
>Jack
Re: onLoad( ) and onSave( ) ?? [message #279417 is a reply to message #279377] Tue, 18 January 2005 08:29 Go to previous messageGo to next message
news:csgpu2$657$1@www.eclipse.org...
They are simple source code files - text based only. Nothing hugely special
about them.
> stripped file?
Not under normal conditions, a given file is assumed to be being worked on
by one user at a time on one workstation.
No, at the moment 'org.eclipse.core.filebuffers.documentSetup' is used to
get an entry point to apply partitioning. No other filebuffer/loading
extension points are used.
Thanks for the continued help :-)
Jack
Re: onLoad( ) and onSave( ) ?? [message #279449 is a reply to message #279417] Tue, 18 January 2005 10:47 Go to previous messageGo to next message
>about them.
>>stripped file?
OK, then I'd implement a my own subclass of TextFileDocumentProvider.
Take a look at JDT UI's PropertiesFileDocumentProvider and how/where
it's used (also check plugin.xml ;-).
HTH
Dani
>Jack
Re: onLoad( ) and onSave( ) ?? [message #279456 is a reply to message #279449] Tue, 18 January 2005 11:28 Go to previous message
news:csjb2d$53l$1@www.eclipse.org...
I'll give that a go then. Although I can't cross reference the JDT as it's
open-source. I'm not certified to look at open source Eclipse (proves to be
a interesting, if annoying, hurdle in my learning!).
Thanks very much for your help!
Jack
Previous Topic:ProjectionDocument and the LineTracker.
Next Topic:Building 3.1 I20050112-1200 for linux-gtk-ppc
Current Time: Sun Nov 09 15:16:16 EST 2025
Powered by FUDForum. Page generated in 0.04084 seconds
