Home » Eclipse Projects » Eclipse Platform » 3.1 M4 & JSSE
3.1 M4 & JSSE [message #278800] Fri, 07 January 2005 08:12 Go to next message
I have an application that uses SSL. It runs fine from the command line.
When I run it in eclipse, it bombs with the trace below. I'm using JDK
1.5.0_01.
Clearly, some library isn't being found. Anyone have any idea what it might
be?
Thanks much.
Steve Buroff
javax.net.ssl.SSLKeyException: RSA premaster secret error
com.sun.net.ssl.internal.ssl.PreMasterSecret.<init>(PreMasterSecret.java:86)
com.sun.net.ssl.internal.ssl.ClientHandshaker.serverHelloDon e(ClientHandshaker.java:514)
com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage (ClientHandshaker.java:160)
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Handshak er.java:495)
com.sun.net.ssl.internal.ssl.Handshaker.process_record(Hands haker.java:433)
com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSoc ketImpl.java:815)
com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHan dshake(SSLSocketImpl.java:1025)
com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SS LSocketImpl.java:1038)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsCli ent.java:405)
sun.net.www.protocol.https.AbstractDelegateHttpsURLConnectio n.connect(AbstractDelegateHttpsURLConnection.java:170)
sun.net.www.protocol.http.HttpURLConnection.getOutputStream( HttpURLConnection.java:828)
sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputS tream(HttpsURLConnectionImpl.java:230)
com.omni.tradesports.comm.TradeSportsServer.sendRequest(Trad eSportsServer.java:445)
com.omni.tradesports.comm.TradeSportsServer.getLogin(TradeSp ortsServer.java:219)
at com.omni.tradesports.user.UserManager.login(UserManager.java :136)
at com.omni.tradesports.OmniTrade.<init>(OmniTrade.java:121)
at com.omni.tradesports.OmniTrade.main(OmniTrade.java:62)
Caused by: java.security.NoSuchAlgorithmException: Cannot find any provider
supporting RSA/ECB/PKCS1Padding
at javax.crypto.Cipher.getInstance(DashoA12275)
at com.sun.net.ssl.internal.ssl.JsseJce.getCipher(JsseJce.java: 90)
at com.sun.net.ssl.internal.ssl.RSACipher.<init>(RSACipher.java:35)
at com.sun.net.ssl.internal.ssl.RSACipher.getInstance(RSACipher .java:69)
com.sun.net.ssl.internal.ssl.PreMasterSecret.<init>(PreMasterSecret.java:82)
.... 16 more
Re: 3.1 M4 & JSSE [message #278822 is a reply to message #278800] Fri, 07 January 2005 12:37 Go to previous messageGo to next message
Originally posted by: ya_xiang.hotmail.com
please check out jdk docs
at guide/security directory
Java Secure Socket Extension(JSSE)
Reference Guide
for the java2 platform standard edition 5
at chapter TroubleShooting
Regards.
xiangya
"Steven Buroff" <sburoff@optonline.net> д
Re: 3.1 M4 & JSSE [message #278830 is a reply to message #278800] Fri, 07 January 2005 17:39 Go to previous messageGo to next message
Hi, maybe you can reference this:
If you are using JDK 1.4, or later, you must use the signed jar for the
provider and you must download the unrestricted policy files for the Sun JCE
if you want the provider to work properly. The policy files can be found at
the same place as the JDK download. Further information on this can be found
in the Sun documentation on the JCE. If you have not installed the policy
files you will see something like:
java.lang.SecurityException: Unsupported keysize or algorithm parameters
at javax.crypto.Cipher.init(DashoA6275)
Regards.xiangya"Steven Buroff" <sburoff@optonline.net> д
Re: 3.1 M4 & JSSE [message #278840 is a reply to message #278830] Sat, 08 January 2005 08:54 Go to previous messageGo to next message
You missed the key fact: "the program runs correctly when executed from a
Windows cmd window". It only fails when run from Eclipse (an application
launcher). It must have something to do with how eclipse is setting up the
environment.
Steve
"xiangya" <ya_xiang@hotmail.com> wrote in message
news:crn337$p50$1@www.eclipse.org...
> JCE
> at
> found
Re: 3.1 M4 & JSSE [message #278850 is a reply to message #278840] Sat, 08 January 2005 16:52 Go to previous messageGo to next message
1, set a new JRE to your jre home not jdk home.
2,configure your java application laucher item and set bootstrap entries to
null(remove default entries) and
3, run it, and you will see jre/bin/javaw.exe without bootstrap option and
just with only classpath option.
Addition, from stack trace message there should be an another message class
already in class path.
Regards.
xiangya
Re: 3.1 M4 & JSSE [message #278864 is a reply to message #278850] Sun, 09 January 2005 09:49 Go to previous message
That worked. Thank you very much for the help.
Steve
news:crpkmp$4sp$1@www.eclipse.org...
> to
> class
> Regards.
> xiangya
Previous Topic:extension-point DocumentCreation
Next Topic:3.1M4 build error
Current Time: Wed Nov 05 15:19:02 EST 2025
Powered by FUDForum. Page generated in 0.04587 seconds
