Need help to interpret Kepler start up error message [message #1520999] |
Sun, 21 December 2014 14:37 |
Ralph Deffke Messages: 5 Registered: December 2014 |
Junior Member |
I am running Kepler x64, JAVA 8 x64 on win8.1 x64.
This Error is new after using the IDE successfully before.
I have also the 32bit Kepler version isnstalled, and started the 32 Kepler version before this error occured.
How to cure this problem ?
Help !
here the error log
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.8.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.cpp.product
Error
Sun Dec 21 14:29:54 CET 2014
Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
at org.eclipse.rse.files.ui.resources.SystemTempFileListener.checkLocalChanges(SystemTempFileListener.java:379)
at org.eclipse.rse.files.ui.resources.SystemTempFileListener.checkLocalChanges(SystemTempFileListener.java:386)
at org.eclipse.rse.files.ui.resources.SystemTempFileListener.resourceChanged(SystemTempFileListener.java:218)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:396)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1531)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:45)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Thanks a lot
FUDForum. Page generated in 0.08777 seconds
