Re: TableField as template? [message #1555340 is a reply to message #1519025] |
Fri, 09 January 2015 19:18 |
Maybe this should be in its own topic?? I don't know
I have a multi-column tablefield in a form. How do you handle loading in multiple rows( or records) into the formfield from database? The form is for orders where the details are mapped to the fields using an 'orderService' from the database. Then in the 'orderitems' field which is a 'tablefield' I want to load all corresponding items from the database using the order number. I have a variable in the form passing the orderNr to the SQL statement on the server side and this maps correctly to the fields so i know it works. My problem is loading the data into the table field. I know its something stupid I am missing. Can anyone help?
FUDForum. Page generated in 0.03222 seconds
