Home » Eclipse Projects » Eclipse Platform » Get IFile in a project from string
Get IFile in a project from string [message #277979] Mon, 20 December 2004 08:42 Go to next message
Originally posted by: mcico.gmx.ch
I have a question, is there an easy way to get an IFile from a String?
I have the project and search a specific and existing file in it. But
with the getFile() and the findMember() methods i get a handle, which
points to a wrong place.
// example of what i want
IProject project =
ResourcesPlugin.getWorkspace().getRoot().getProject(<projectname >);
IFile file = // now a method to get the file, which might be deeper
down the resource tree than one level
greetings
marco
Re: Get IFile in a project from string [message #278001 is a reply to message #277979] Mon, 20 December 2004 12:47 Go to previous messageGo to next message
Originally posted by: tschlat.gmx.de
Marco Cicolini wrote:
> Hi
> IProject project =
> greetings
> marco
I hope this is what you want. At least it works fine for me:
IProject storageProject = workspace.getRoot().getProject(STORAGE_PROJECT);
try {
// just make sure your project is up to date
storageProject.refreshLocal(IResource.DEPTH_INFINITE, null);
} catch (CoreException e1) {
log.error(e1);
IPath path1 = new Path("/client/testclient/test.xml");
IResource resource = storageProject.findMember(path1);
IPath localPath = ((File)resource).getLocation();
// localPath is now "E:/dev/workspace/storage/client/testclient/test.xml"
Re: Get IFile in a project from string [message #278002 is a reply to message #277979] Mon, 20 December 2004 13:40 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
The answer depends on what your string looks like. Is it a file system
path (like c:\temp\myProject\MyFile.txt)? In this case
IWorkspaceRoot.findFilesForLocation will help. If the path is a
workspace path such as "/Project/Folder/File.txt", then
IWorkspaceRoot.findMember is what you're looking for.
> I have a question, is there an easy way to get an IFile from a String? I
> have the project and search a specific and existing file in it. But with
> the getFile() and the findMember() methods i get a handle, which points
> to a wrong place.
> IProject project =
> IFile file = // now a method to get the file, which might be deeper down
Re: Get IFile in a project from string [message #278097 is a reply to message #278002] Wed, 22 December 2004 02:24 Go to previous messageGo to next message
hi there,
well i was not that exact with my question, the String i use to
finde/get the IFile is only the name of the File, i dont have the Path
or other information about it.
Therefore the proposed solution is not working. For now i search the
whole project for the specific filename....
Re: Get IFile in a project from string [message #278125 is a reply to message #278097] Wed, 22 December 2004 15:47 Go to previous messageGo to next message
If you only have the simple file name, then a naive search through the
entire project is the best you can do. Any (and all) directories could
have a file by that name.
> hi there,
Re: Get IFile in a project from string [message #278345 is a reply to message #278125] Wed, 29 December 2004 11:57 Go to previous message
yes, thats what i did. i thought, that the api provides such a function.
Previous Topic:Checking out a project from CVS Branch
Next Topic:editor to view (newbie)
Current Time: Sun Nov 09 19:23:15 EST 2025
Powered by FUDForum. Page generated in 0.06137 seconds
