Home » Eclipse Projects » EGit / JGit » unable to push sources to JGit in Gerrit( Invalid tree a33cf05e7a: duplicate entry names)
unable to push sources to JGit in Gerrit [message #1516007] Thu, 18 December 2014 15:35 Go to next message
Roman Shiryaev is currently offline Roman ShiryaevFriend
we got stuck with the following exception when trying to push sources from an old git repo (hosted not in Gerrit) to a new one in Gerrit (ver. 2.9.3)
Could you suggest any idea for solving the issue? How to eliminate the duplicates properly?
Thanks in advance.
[2014-12-18 13:04:49,814] ERROR com.google.gerrit.sshd.BaseCommand : Internal server error (user XXX account 1000017) during git-receive-pack '/projectname1/module1'
com.google.gerrit.sshd.BaseCommand$Failure: fatal: Unpack error, check server log
        at com.google.gerrit.sshd.commands.Receive.runImpl(Receive.java:176)
        at com.google.gerrit.sshd.AbstractGitCommand.service(AbstractGitCommand.java:101)
        at com.google.gerrit.sshd.AbstractGitCommand.access$000(AbstractGitCommand.java:32)
        at com.google.gerrit.sshd.AbstractGitCommand$1.run(AbstractGitCommand.java:70)
        at com.google.gerrit.sshd.BaseCommand$TaskThunk.run(BaseCommand.java:442)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
        at java.util.concurrent.FutureTask.run(FutureTask.java:262)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292)
        at com.google.gerrit.server.git.WorkQueue$Task.run(WorkQueue.java:364)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
        at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Unpack error on project "projectname1/module1":
  AdvertiseRefsHook: org.eclipse.jgit.transport.AdvertiseRefsHookChain@2453e48cclass org.eclipse.jgit.transport.AdvertiseRefsHookChain
        at com.google.gerrit.sshd.commands.Receive.runImpl(Receive.java:175)
        ... 12 more
Caused by: org.eclipse.jgit.errors.UnpackException: Exception while parsing pack stream
        at org.eclipse.jgit.transport.ReceivePack.service(ReceivePack.java:239)
        at org.eclipse.jgit.transport.ReceivePack.receive(ReceivePack.java:160)
        at com.google.gerrit.sshd.commands.Receive.runImpl(Receive.java:115)
        ... 12 more
Caused by: org.eclipse.jgit.errors.CorruptObjectException: Invalid tree a33cf05e7a: duplicate entry names
        at org.eclipse.jgit.transport.PackParser.verifySafeObject(PackParser.java:1017)
        at org.eclipse.jgit.transport.PackParser.whole(PackParser.java:998)
        at org.eclipse.jgit.transport.PackParser.indexOneObject(PackParser.java:916)
        at org.eclipse.jgit.transport.PackParser.parse(PackParser.java:487)
        at org.eclipse.jgit.internal.storage.file.ObjectDirectoryPackParser.parse(ObjectDirectoryPackParser.java:194)
        at org.eclipse.jgit.transport.BaseReceivePack.receivePack(BaseReceivePack.java:1020)
        at org.eclipse.jgit.transport.BaseReceivePack.receivePackAndCheckConnectivity(BaseReceivePack.java:848)
        at org.eclipse.jgit.transport.ReceivePack.service(ReceivePack.java:191)
        ... 14 more
Caused by: org.eclipse.jgit.errors.CorruptObjectException: duplicate entry names
        at org.eclipse.jgit.lib.ObjectChecker.checkTree(ObjectChecker.java:388)
        at org.eclipse.jgit.lib.ObjectChecker.check(ObjectChecker.java:179)
        at org.eclipse.jgit.transport.PackParser.verifySafeObject(PackParser.java:1015)
        ... 21 more
Re: unable to push sources to JGit in Gerrit [message #1528775 is a reply to message #1516007] Thu, 25 December 2014 23:46 Go to previous message
Posting here the solution given to me by Roberto Tyley in jgit-dev maillist.
You can clean your Git history of duplicate entries with the BFG:
https:// github.com/rtyley/bfg-repo-cleaner/releases/tag/v1.11.1
$ bfg --fix-filename-duplicates-preferring tree
Seasons greetings,
Roberto
Thus, use Roberto's super useful BFG tool to fix all errors that you see in `git fsck`
https:// rtyley.github.io/bfg-repo-cleaner/
Previous Topic:TeamProjectSet repository-folder
Next Topic:Setting up classpath for source control
Current Time: Fri Apr 26 04:17:11 GMT 2024
Powered by FUDForum. Page generated in 0.02763 seconds
