Home » Eclipse Projects » Eclipse Platform » Testing Eclipse with Java 5.0 runtime
Testing Eclipse with Java 5.0 runtime [message #276871] Tue, 30 November 2004 11:32 Go to next message
Originally posted by: bandrews.nospam_bphnx.com
I know that Eclipse is currently being built and tested with J2SE 1.4.x.
I was wondering if anyone out there is using 5.0 to test with. I have
been using Eclipse 3.1M2 with J2SE 5.0 for about a month now, and have
not run into any problems. Just curious about anyone elses experiences.
thanks,
Barry
Re: Testing Eclipse with Java 5.0 runtime [message #276887 is a reply to message #276871] Tue, 30 November 2004 14:27 Go to previous messageGo to next message
Originally posted by: mail.en.bas
I've been running Eclipse 3.0 vith JRE 5.0 on both Linux and Win XP
platforms for about one month.
No problem.
Arnaud
mags75 at club-internet point fr
Re: Testing Eclipse with Java 5.0 runtime [message #276915 is a reply to message #276871] Wed, 01 December 2004 04:10 Go to previous messageGo to next message
> thanks,
> Barry
two weeks, no problems on slackware linux
Re: Testing Eclipse with Java 5.0 runtime [message #277062 is a reply to message #276871] Fri, 03 December 2004 11:07 Go to previous messageGo to next message
Originally posted by: ch180.cs.york.ac.uk
I've been using it with j2se5 since beta 2 in the summer. I have several
problems but I'm not certain that they are related:
Features don't build properly. If compiler compliance is set to 1.4 on all
settings, i get '1.4' target mode requires '-1.4' compliance mode: 1.3 and
the jar for each plugin contains only the xml. Other modes (1.3) work but a
feature.jar is never created so i can't use the update site. V annoying....
Using 3.1M3, I can compile plugins to 1.5 but eclipse doesn't seem to know
how to run them...they simply won't load.
Any ideas?
Chris
"Barry Andrews" <bandrews@nospam_bphnx.com> wrote in message
news:coi7cc$14c$1@www.eclipse.org...
>I know that Eclipse is currently being built and tested with J2SE 1.4.x. I
>was wondering if anyone out there is using 5.0 to test with. I have been
>using Eclipse 3.1M2 with J2SE 5.0 for about a month now, and have not run
> thanks,
> Barry
Re: Testing Eclipse with Java 5.0 runtime [message #277070 is a reply to message #277062] Fri, 03 December 2004 12:59 Go to previous messageGo to next message
> Any ideas?
class files generated with 1.5 are not backwards compatible. If you
compile them with eclipse's 1.5, then you must be running eclipse with a
1.5 JRE. also 3.1m3 is not yet 100% compatible with the sun 1.5JRE.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Testing Eclipse with Java 5.0 runtime [message #277096 is a reply to message #277070] Fri, 03 December 2004 23:59 Go to previous messageGo to next message
This is not completely true. By default javac 1.5 compiles the code with
-target 1.5. This means that the resulting .class file won't run on a
1.4 VM, but if you are not using 1.5 constructs, then you can compile
with a JDK 1.5 using a lower target value like -target 1.4 and the
resulting .class files will run on a 1.4 VM.
Olivier
Re: Testing Eclipse with Java 5.0 runtime [message #277207 is a reply to message #276871] Mon, 06 December 2004 15:00 Go to previous message
I've been running with Java 5.0 since back when the first beta appeared.
Well, except for when I've been testing VM-specific bugs/features in
Eclipse. I haven't encountered any notable problems.
cheers,
d.
Previous Topic:Linking into PreferencesPages
Next Topic:[JFace] ToolBarManager
Current Time: Wed Nov 05 15:07:29 EST 2025
Powered by FUDForum. Page generated in 0.03830 seconds
