Home » Eclipse Projects » Eclipse Platform » replace tab with space
replace tab with space [message #276817] Mon, 29 November 2004 12:58 Go to next message
Originally posted by: waltereo.hotmail.com
How can I replace tabs with space in my existing code ??
Re: replace tab with space [message #276845 is a reply to message #276817] Tue, 30 November 2004 05:06 Go to previous messageGo to next message
If it's java code: define a code formatting style that specifies to use
spaces and reformat your code. The wanted or unwanted side-effect will
be that your code is reformatted.
-tom
Re: replace tab with space [message #276933 is a reply to message #276817] Wed, 01 December 2004 08:28 Go to previous messageGo to next message
If you havent got too much code, you could do a search and replace manually.
Find: \t
Replace: (4 spaces)
and check the "Regular expressions" option.
"Waltereo" <waltereo@hotmail.com> wrote in message
news:cofnta$jei$1@www.eclipse.org...
> Thanks
Re: replace tab with space [message #276935 is a reply to message #276933] Wed, 01 December 2004 10:07 Go to previous message
Originally posted by: bob.news.gmx.net
"Jayshan" <jr200@doc.ic.ac.uk> schrieb im Newsbeitrag
news:cokgt5$kbu$1@www.eclipse.org...
manually.
> Find: \t
> Replace: (4 spaces)
That's not guaranteed to yield properly indented code, is it? A tab is
not always four spaces - could be less depending on the position of the
tab.
Kind regards
robert
> > Hi,
> > Thanks
Previous Topic:Restore a deleted project
Next Topic:Programmatically retrieve platform configuration
Current Time: Mon Jul 28 05:05:19 EDT 2025
Powered by FUDForum. Page generated in 0.26357 seconds
