Home » Eclipse Projects » Eclipse Platform » Eclipse Plugin XML Spec.
Eclipse Plugin XML Spec. [message #276767] Sun, 28 November 2004 00:16 Go to next message
Originally posted by: bud.curtis.direcway.com
I am not sure where I should ask this question, so I figured I go to the
platform first. If this is the wrong forum just point me to the more
appropriate forum. Is there a document that specifies all the tags and
there uses in the plugin.xml? If one exists, can I access it on the WEB.
Bud Curtis
Colorado Springs, CO
Re: Eclipse Plugin XML Spec. [message #276772 is a reply to message #276767] Sun, 28 November 2004 07:46 Go to previous messageGo to next message
There is such a documentation in the Eclipse Help: Help > Help Contents,
then select Platform Plugin Developer Guide > Reference > Other Reference
Information > Plugin Manifest.
The docs are also online as pdf at:
http://eclipse.org/documentation/main.html
Ciao,
Leif
Re: Eclipse Plugin XML Spec. [message #276781 is a reply to message #276772] Sun, 28 November 2004 13:12 Go to previous message
Terrific, Thank you Leif
Bud Curtis
"Leif Frenzel" <himself@leiffrenzel.de> wrote in message
news:coch7a$jev$1@www.eclipse.org...
WEB.
> Ciao,
> Leif
Previous Topic:How do I empty NavigationHistory?
Next Topic:Problem with drag and drop and AbstractTextEditor
Current Time: Mon Nov 10 07:15:51 EST 2025
Powered by FUDForum. Page generated in 0.04177 seconds
