Home » Eclipse Projects » BPMN 2.0 Modeler » Code snippet for export diagram feature(Is that possible to write a java api to export a image from bpmn2 model)
Code snippet for export diagram feature [message #1508846] Fri, 12 December 2014 14:28 Go to next message
Hey,
I am looking for the code snippet for export diagram feature in bpmn2 modeler.
Actually, i am currently working on a project where i have a requirement to create a image from a bpmn2 file through programmatically. Basically, the api would have one argument as a bpmn2 file, and the output of that api should be a image file.
Could any one please help me in this regards, i got tired of looking for the same stuff in google but did not get much helped from that.
Your help will be much appreciated.
You can email me at badabapidas@gmail.com
Looking forward for your responses. Thanks in advance.
Bapi
Re: Code snippet for export diagram feature [message #1842655 is a reply to message #1508846] Sun, 27 June 2021 04:44 Go to previous messageGo to next message
Please sir if u have the answer contact me in my email saighe2016@gmail.com or give me the solution right here
Re: Code snippet for export diagram feature [message #1843616 is a reply to message #1508846] Tue, 10 August 2021 17:38 Go to previous message
the export feature in the Eclipse BPMN modeller is a feature of the GEF/graphiti API (https://www.eclipse.org/graphiti/). There is no special implementation in the BPMN plugin itself. It comes from the magic of the Eclipse Platform.
Previous Topic:BPMN 2.0 Modeler Plugin
Next Topic:How to pick an Icon in a CustomTask
Current Time: Tue Nov 04 00:38:06 EST 2025
Powered by FUDForum. Page generated in 0.05464 seconds
