Object Mapping Not Working [message #1508723] |
Fri, 12 December 2014 12:07  |
I am using Jubula through the Eclipse (Kepler) for Testers package. I am running on Red Hat Enterprise Linux Client (Tikanga) 64 bit. If I configure my test project for the SWT toolkit, then I get a JVM crash upon start AUT. IF I configure for an RCP toolkit (and drop the appropriate RCP support into my plugins and add to config.ini), then the AUT will start, however, during object mapping the green highlight feature will only ever briefly flicker, then disappear when hovering over the controls.
This AUT does have customized SWT controls, including canvases, so I would expect to need to extend those controls to include Tester classes. However, I don't think that ALL controls in the AUT are custom.
Starting my AUT external to eclipse works nominally. The build was performed by a Hudson job invoking Maven, but I don't see why that should matter.
Do I have a configuration problem?
Thanks!
FUDForum. Page generated in 0.03555 seconds
